rebuild 350 to a 383
Old Jul 3, 2011 | 07:09 PM
Jaws031's Avatar
Car: 88 camaro
i going to rebuild my 350 to a 383 next year. what all parts do i need to get it done.
Old Jul 3, 2011 | 07:15 PM
Guest
Guest
Posts: n/a
Re: rebuild 350 to a 383
It's mostly just the stroker crank, matching pistons, and a bit of clearance grinding to the block and maybe the tops of the rod bolts.
Other than that, it's about the same as rebuilding any other 350.
Old Jul 3, 2011 | 08:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
3.75 Stroke, bore the cylinders .030 is really all that "needs" to be done along with clearancing the crank so that it can accept it. You can buy rotating assembly kits already set up for it so all you need to do is bore the cylinders.
All the 350 parts will bolt up to the 383 otherwise. Now, if you want performance, it's all about how much $$ you want to spend.
fbirdroller
Sep 2, 2015 10:27 PM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
