Question about pieces found under valve cover
Old Jul 4, 2011 | 03:49 PM
michael_0u812's Avatar
Hi everyone,
I've been working on cleaning up the outside of my engine. I pulled the valve covers to repaint them and found these just sitting on the head:
I assume the one on the left is a valve seal but I'm not sure about the other two. Any help would be appreciated!
-Mike
Old Jul 4, 2011 | 04:14 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: Question about pieces found under valve cover
Are all the retainers/valves intact?
Old Jul 4, 2011 | 09:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd pull all the valve springs and start looking for ones with missing components.
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Those are all parts of most likely the one valve seal. Have you changed cam or rocker ratio lately?
Old Jul 4, 2011 | 09:47 PM
Robby12's Avatar
Ya looks like those are all parts uses in a positive locking valve seal
Old Jul 6, 2011 | 12:17 AM
Wow, that was fast guys!
So it looks like I need a new valve seal. I guess I should probably get a whole set since I doubt they've ever been replaced. Are there any concerns of damaged parts because of this?
Old Jul 6, 2011 | 01:28 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The lack of valve seals arent going to do much but cause extra oil consumption. Do you see much/any blue smoke out the back when you start it up or engine-brake?
The parts floating around in your oil is a little scary, but they seem big enough they wont get drawn through the oil pump - hopefully.
Old Jul 6, 2011 | 01:46 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Looks like all the metal bits are there. Dont know about the rubber seal stuff. That will migrate around the motor and get into places where it doesnt belong. Probably be a good time to locate the one that came apart and see if you can retrieve all the peices.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
bjpotter
Aug 12, 2015 06:06 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
