fuel and carb problems
Old Jul 4, 2011 | 09:19 PM
BillyBLKPearl91's Avatar
Car: 91 camaro rs
Engine: 305 carb
91 rs the guy i got it from had it carb already with a fuel pump electric fuel pump in the front he blocked off the return line and put a cheap fuel pressure regulator. the distributor vac line wasnt going to the carb and the carb was leaking a lot of gas.. now i want to take off the cheap fuel pressure regulator n buy a better one that does its job correctly but i dont know which one to get, if i need to connect to the return line to the fuel pressure regulator too.
Old Jul 4, 2011 | 10:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel and carb problems
You need a Mallory 4309 or similar return-style regulator, and use the return line - this assumes the in-tank electric pump has not already burnt itself up.
If the intank pump is dead, it needs removed, and either replaced with another pump, or replaced with a carb pickup, at which point you can use any external electric pump or even a mechnanical pump on the block and not worry with the fuel pressure regulator.
Old Jul 4, 2011 | 11:49 PM
affliction1's Avatar
Car: 89 chevy camaro rs
you dont have to remove the old in tank,just un hook it and use the wiring harness for it to run inline eletric,saves time and effort,run the original fuel line.the in tank doesnt cause any drag and you dont have to drop the rear and tank
Old Jul 5, 2011 | 11:31 AM
Car: 91 camaro rs
Engine: 305 carb
ok i heard of using the wiring but this is what i got going on two pumps intank and this other cheap
Attached Thumbnails fuel and carb problems-cimg5261.jpg   fuel and carb problems-cimg5262.jpg
Old Jul 5, 2011 | 11:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Except your inline pump won't get great flow sucking through the dead pump in the tank.
Old Jul 5, 2011 | 12:03 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree. Mallory 4309 with return style should work if the intank is still good. If it was a fuel injection pump prior it's getting way to much pressure to be bottle necked by the non-return style regulator. In that case it's pushing 40+ psi into a regulator that's trying to stop it at 6.0 to 8.5 psi. That'll build up heat in the pump and kill the pump. It also can/will overpower the regulator and force more to the carb causing leaks and other issues.
You shouldn't try to pull fuel through a dead pump. It'll just make the new pump work harder and kill it. Also when fuel pumps die they sometimes tend to send debris through the lines.
Old Jul 5, 2011 | 02:07 PM
Car: 91 camaro rs
Engine: 305 carb
so i should take off the pump that is in the front leave the intank and add then just add the regulator, im like 99% sure the intank is still working thats why it flooded the carb i shoul put the regulator before the carb, like in figure 3b right...well like the 2nd sample down
Old Jul 5, 2011 | 06:47 PM
Car: 1992 RS
Engine: Carbed 350
Yes, put regulator under the hood. The larger 3/8th line is the feed, runs to any side port on the 4309. Smaller 5/16 line is return, connects to bottom of the 4309. Then another 3/8th line from any other side port on 4309 to your carb (with another small filter inline). You can get metric-to-NPT adapters at any local hardwarte store in the brass plumbing section, as well as the 5/16 and 3/8 hose barbs.
Old Jul 6, 2011 | 12:35 AM
Old Jul 6, 2011 | 12:37 AM
ive driven my car 10000 miles with dead pump in tank no problems,with el cheepo mrgasket 5-9 psi inline pump
Old Jul 6, 2011 | 12:41 AM
hay where you have your pump is in the wayyyy wrong place,should be above the rearend,screwed to the back of the seat right next to the tank and use the wiring harness for reg fuel pump,they arent good at pulling fuel but there great at pushing it.
Old Jul 6, 2011 | 07:22 PM
Car: 91 camaro rs
Engine: 305 carb
does any one have any pic to see some examples on the setups....im leave the old pump n remove the mr gasket pump
Old Jul 6, 2011 | 07:24 PM
Engine: 383 SBC
Pic of a return-style mallory?
Old Jul 7, 2011 | 12:06 AM
ill take a pic in the morning of my setup
Old Jul 16, 2011 | 08:41 PM
Car: 91 camaro rs
Engine: 305 carb
hey guy that have the mallory 4309 return-style regulator what is the lil thing that comes with it there is 2 screws and the bracket n this lil thing what is that for?
Old Jul 16, 2011 | 09:15 PM
Engine: 383 SBC
Bracket is used on the top side to mount it. Make sure where you pick you can get to the set screw easily. That's how you adjust the pressure.
Old Jul 17, 2011 | 04:52 PM
Car: 91 camaro rs
Engine: 305 carb
what do you mean on the top side to mount pic one or pic two
Attached Thumbnails fuel and carb problems-cimg5268.jpg   fuel and carb problems-cimg5270.jpg
Old Jul 17, 2011 | 05:00 PM
Car: 91 camaro rs
Engine: 305 carb
and for the lil thing that comes with the screw and bracket #1 is screws #2 is bracket #3is the lil thing i dont know were it goes does any on knows
Old Jul 17, 2011 | 07:29 PM
Engine: 383 SBC
Which ever way you want to mount it should work. I would just recommend the set screw in a place you can adjust it if necessary. That set screw on the top is what will adjust the pressure to the carb. Mine is mounted like your #2 picture over by the washer fluid bottle, since it was close to the factory feed and return lines.
Looks like #3 is the brass spacer in the instructions used to modify pumps.
http://static.summitracing.com/globa...s/maa-4309.pdf
Old Jul 24, 2011 | 08:37 PM
Car: 91 camaro rs
Engine: 305 carb
so i finally got work going and this is how i got my setup i havent got the car started some how the battery is dead im see in the morning after i charge the battery
Attached Thumbnails fuel and carb problems-cimg5298.jpg   fuel and carb problems-cimg5294.jpg
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
