What size are the stock exhaust pipes on a 91 camaro 305 tbi?
Old Jul 5, 2011 | 12:41 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Hey guys, I have an almost stock 91 camaro with a 305, and I want to know what size the stock exhaust pipes are? I don't have enough for a cat-back exhaust kit so I'm just going with a muffler, so I want to make sure I get the right one
Old Jul 5, 2011 | 09:10 AM
Guest
Guest
Posts: n/a
Re: What size are the stock exhaust pipes on a 91 camaro 305 tbi?
2.25"
Old Jul 5, 2011 | 10:32 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Ok, so the muffler inlet and outlets would have to be 2.5" to fit over the pipes, right?
Old Jul 5, 2011 | 01:07 PM
Guest
Guest
Posts: n/a
No. Your over-axle-pipe is 2.25" outside diameter. Any performance muffler sold as 2.25" is going to have an inlet size of 2.25" inside diameter. Just cut the stock muff off, slip the loud muff on, and clamp it.
Old Jul 5, 2011 | 01:18 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Oh ok, thanks man, and I have to cut the old one off?
Old Jul 5, 2011 | 01:24 PM
Guest
Guest
Posts: n/a
If it's original to the car, then it should be fully welded.
Old Jul 5, 2011 | 01:27 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Ok thanks, a hack saw should take care of that
Old Jul 5, 2011 | 01:32 PM
Guest
Guest
Posts: n/a
Yes, but be forewarned, there's not much room for sawing. Most guys use an electric sabre saw.
Old Jul 5, 2011 | 01:33 PM
Guest
Guest
Posts: n/a
BTW, you can rent those if you don't own one and can't borrow one.
Old Jul 5, 2011 | 01:35 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I didn't think of that
db057
Aug 22, 2015 08:17 PM
Linson
Aug 21, 2015 02:12 PM
92purpz28
Aug 11, 2015 02:30 PM
MENINBLK
Aug 5, 2015 11:58 PM
