holley carb pros needed
Old Jul 12, 2011 | 11:08 PM
wild thing's Avatar
Car: 92 Camaro RS 25th Anniversary
Engine: 3.1L V6
Transmission: 5 speed
Axle/Gears: 10 bolt with 3.42s
i have a holley carb and i need to know what cfm it is, and any other info you can give me.
here is the list number 4772-1 and this number was above it 679344
Old Jul 13, 2011 | 01:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: holley carb pros needed
Is off a '71 Chevy 366ci big block Truck or bus engine
Old Jul 13, 2011 | 08:32 AM
wild thing's Avatar
Engine: 3.1L V6
wow, thats what it is off of? do you know what cfm it is?
Old Jul 13, 2011 | 11:52 AM
It'll be about 600, FWIW.
Definitely NOT a performance carb.
Old Jul 13, 2011 | 05:21 PM
wild thing's Avatar
Engine: 3.1L V6
theres no way it is only a 600cfm, not on a big block for a truck or bus, my 79 gmc came factory with an 800cfm quadrajet on a 350 chevy sb and thats a proven fact, the build sheet doesn't lie.
Old Jul 13, 2011 | 05:51 PM
What does a Q-Jet on a 79 GMC have to do with a Holley on a 71 gas-burner dump truck?
Those old stock Holleys were in the neighborhood of 600 CFM. It wasn't "rated" that way, it just so happens that it's about that size. It just is what it is. Not that it matters; it's not a performance carb, so its "CFM rating" is sort of irrelevant. That's about like asking what the cargo capacity of a Porsche Boxster is, or the 0 - 60 time of a school bus.... that information wasn't necessary for describing the application at hand, so it wasn't generated.
Old Jul 14, 2011 | 08:27 AM
wild thing's Avatar
Engine: 3.1L V6
i am just saying a dump truck will have a bigger carb on than just a 600cfm, not when a small block chevy can have a 800cfm something doesn't make sense, a 600cfm carb on a dumptruck or bus bould slag an putter down the road because the carb is not rated for it. its like putting a 2 barrel on a but and expecting it to work, not gonna happen. thats why i am saying it cant only be a 600cfm.
Old Jul 14, 2011 | 08:55 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Better place a call to 1971 and tell them they got it wrong, then. While you're at it, put your Qjet on a flowbench and see what happens.
Old Jul 14, 2011 | 10:31 PM
wild thing's Avatar
Engine: 3.1L V6
well nobody said this info came out of a book, if you got it out of a book then i'll believe it, but otherwise it could just be a guess
Old Jul 14, 2011 | 11:30 PM
canadian's Avatar
Car: 84 T/A
Axle/Gears: 3.73 Posi
The reason they had a 600cfm carb was because the engine doesn't need anything more. You aren't redlining a dump truck or doing burnouts in a school bus. At my workplace there is a 60's-70's firetruck with a 427 big block that only has a 750cfm holley on it. You just don't need a high cfm carb on a vehicle that doesn't operate at high rpm.
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
