500 - 1700rpm idle
Old Jul 16, 2011 | 02:58 PM
deano17's Avatar
500 - 1700rpm idle
I have a stock 89 camaro rs with the 305 and when i start it up, the idle speed fluctuates from 500 to 1700rpm. it does this for about 2 minutes and then it levels out at about 1200 rpm. I replaced the O2 sensor, EGR valve, spark plugs, wires, cap, rotor, coolant temp sensor, thermostat, rad cap, a ripped vacuum line, and air filter. Any ideas on what could be causing this issue?
Old Jul 16, 2011 | 03:52 PM
Lumarus's Avatar
Car: 1982 Z28 T-Top Camaro
Engine: Vortec 355
Transmission: T-5 5Speed Manual
Axle/Gears: Stock Limited Slip
Re: 500 - 1700rpm idle
id say there is a vaccum leak sumwhere still. CAUTIOUSLY with engine running, try spraing litely in mists carb cleaner or starter fluid around intake area n see if ur motor idles higher any.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
