what part of timing marks is 6 degrees?? L98
Old Jul 22, 2011 | 06:39 PM
jaygt's Avatar
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
ok i bought a timing gun and set timing on my new distributer. there are a bunch of triangles and one big one by balancer. if anyone can explaine the it to me that would help
Old Jul 22, 2011 | 06:52 PM
Damon's Avatar
Re: what part of timing marks is 6 degrees?? L98
The bottom of the big "V" is 0* (TDC). To the left of that every point is 4* advanced (4, 8, 12, 16 degrees advanced). To the right of the big "V" every point is 4* retarded.
So you want it between the first 2 points to the left of the big "V" for the factory/stock 6* BTDC setting.
Old Jul 22, 2011 | 07:01 PM
jaygt's Avatar
great thanks! is 8 degrees better for performance? with high octane gas and no ping? i think thats where the timing ended up. its on the second point on left of big v
Old Jul 22, 2011 | 09:54 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
no, look at the attachment i sent. there is the center of the big v,that is 0 degrees, then the first tip from there is 4, six is the center of the next v.
Old Jul 22, 2011 | 09:55 PM
ninetyone's Avatar
Axle/Gears: 3:42
look at the attachment.
Old Jul 22, 2011 | 09:58 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
ive got mine on 8 degrees it dont have a pinging in it
Old Jul 22, 2011 | 10:01 PM
ninetyone's Avatar
Axle/Gears: 3:42
your right,that is 8. i just looked at the chart. there are 3 v's total. each tip goes 4,8,then skips to 12. inbetween is 6 and 10
Old Jul 22, 2011 | 10:02 PM
jaygt's Avatar
i dont see an attachment ? can you try again or put a link
Old Jul 22, 2011 | 10:04 PM
ninetyone's Avatar
Axle/Gears: 3:42
all cars like different timing, i cant run 4 degrees btdc without 92 octane.
Old Jul 22, 2011 | 10:05 PM
ninetyone's Avatar
Axle/Gears: 3:42
send me your email address, i sent it twice on here
Old Jul 22, 2011 | 10:46 PM
edmonds1383's Avatar
Car: 92 Camaro RS
I have been thinking about adjusting the timing on my 92 rs by 6 degrees....i have heard rumor that it will bosst performance. Have i been lead in the wrong direction...or is this true. And it that the only adjustments i need to make...or do i need to make other adjustments along with the change in timing?
Old Jul 22, 2011 | 11:13 PM
Damon's Avatar
Most stock motors you can bump it by about 4* over stock spec for a bit more performance with little or no downside. MOST. Not all. Depends on the individual motor and how aggressive the original timing curve is.
It's a try-it-and-see thing. And because all these EFI motors have a knock sensor you're unlikely to ever hear any detonation like on the old carbureted engines (some of which also had knock sensors way back to the early 80s).
If you want to be scientific about it, get a scan tool and see if the knock sensor is causing timing to be pulled out. If bumping up the initial timing causes the knock sensor to start pulling out timing you're better of leaving the timing where it was in the first place. By the time the knock sensor kicks in it's gotta pull out quite a bit of timing to stop the detonation.
Old Jul 23, 2011 | 12:40 AM
Car: 92 Camaro RS
Thanks for the input. It is on my list of things to do in a month or so when i get back from this deployment.
Old Jul 23, 2011 | 09:46 AM
ninetyone's Avatar
Axle/Gears: 3:42
what octane rating are you using? Is your knock sensor pulling out timing?
Old Jul 23, 2011 | 10:04 AM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
ran 93 octane and an extra 4 degrees timing. with no problem
Old Jul 27, 2011 | 06:37 PM
A K racin's Avatar
did you notice any power increase from runnung your timming 4 degrees advance
Old Jul 27, 2011 | 06:47 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
With the gas you want to run, advance in incriments of 2 deg untill there is pinging, then back it down. (You will have to test drive it to hear the pinging.) That will be your best advanced you can have for your engine. The higher the octane, the more advanced you can go.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Thirim
Aug 9, 2015 06:19 PM
1nastygta
Aug 8, 2015 07:38 PM
