IAC Question
Old Jul 26, 2011 | 05:31 PM
rayres88's Avatar
Car: 91 GTA
Engine: 5.7 liter v8
Transmission: 700 r4
IAC Question
I pulled the IAC on my 91 GTA 5.7 and I was wondering if I should be able to push in the needle against the spring. When I do push it doesn't move a lick, completely stuck and hard. I thought it should be free to move unless it only moves with electrical current. Was wondering if since it does not move by a push of my finger if it was stuck and bad. Although I thought it seemed to be working when it was in the car. I could tell the idle would change when I would turn on the AC. Although I would get major loping when the car was completely to running temp. My fuel injectors were bad anyway and I am replacing them, that is why I have everything apart and decided to look inside the IAC hole and clean everything out. Pushed on pintle and doesn't move at ALL. Is this normal before I spend money on a new one?
Old Jul 26, 2011 | 06:46 PM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
Re: IAC Question
I think it shouldn't move since the motor inside actually threads it in or out. You might just be feeling the play in the threads if you push it.
Old Jul 26, 2011 | 06:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: IAC Question
you should be able to rock it back and forth and actually push it in. if you are unable to move it in then it is bad.
rayres88's Avatar
Car: 91 GTA
Re: IAC Question
Well my point is I feel no play at all. It does not move.
Old Jul 26, 2011 | 06:54 PM
rayres88's Avatar
Car: 91 GTA
Re: IAC Question
Thanks one92rs. This thing is frozen like a block of ice. Doesn't twist turn push in against spring nothing....I even tried pushing the pintle against a wall and it would not break loose.
Old Jul 26, 2011 | 09:13 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: IAC Question
If it is the original IAC, you should probably replace it. It sounds like it is not functional anyway. I think I payed about 20+ bucks for a new one.
Old Jul 26, 2011 | 09:15 PM
rayres88's Avatar
Car: 91 GTA
Re: IAC Question
I don't know where you got it for 20. They are like 80 at advance auto for the bwd.
Old Jul 26, 2011 | 09:18 PM
Re: IAC Question
Alright, I was thinking of the TPS. Sorry my mistake. By the way, did you take carb clearer and give it a good cleaning?
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
