power brakes
Old Jul 31, 2011 | 07:52 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
power brakes
as u may know i just got a new motor installed but having problems with power brakes not having enough vacum at idle. my question is if i hook the pcv valve back up will that give me more vacum or do i need to get a vacum canister.
Old Jul 31, 2011 | 08:01 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: power brakes
I had to get a canister, it works well...
Old Jul 31, 2011 | 08:02 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: power brakes
Is the check valve/filter looking deal bad on your line from the intake to the booster? How many inches are you pulling at idle?
Old Jul 31, 2011 | 08:22 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: power brakes
valve worked on last motor. and im not sure what the vacum is at idle dont have the tool to check
Old Jul 31, 2011 | 05:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: power brakes
Vac guage avail at any parts store for under $10. Might try increasing timing some, and setting isle adjustment lower to compensate idle - I did this on my car to get more vacuum.
Old Jul 31, 2011 | 07:35 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: power brakes
the guy who broke it in st the timing 36 total
Old Aug 1, 2011 | 08:31 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: power brakes
So I ordered a cannister from summit. Instructions say about keeping the vacum brake filter if equiped. Is that the black thing or is that the check valve. If check valve do I need to keep it in the line
Old Aug 1, 2011 | 08:44 PM
J91's Avatar
J91
Re: power brakes
Keep checkvalve/filter inline, clean w/brakecleaner if needed, they do get dirty over time....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
stalkier
Aug 13, 2015 12:59 PM
