Simple Accessory Mounting Bracket Question
Old Aug 1, 2011 | 09:37 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
This could very well be a question with an "it doesn't matter," but better to ask than to guess. New 350 build...do I torque things such as the intake, the water pump, and the headers...THEN add the alternator/power steering/AC brackets, or do I try to match all of those to their spot and torque everything with the brackets in place the first time?
Thanks!
Scott
Old Aug 1, 2011 | 09:55 PM
Guest
Guest
Posts: n/a
Re: Simple Accessory Mounting Bracket Question
Brackets last, not first, IMHO.
Old Aug 2, 2011 | 02:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yeah - the accessories are just that - accessories - worry about them last after motor is built, sealed up, buttoned down, and after install back into car.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
