Perimeter bolt heads
Old Aug 9, 2011 | 12:09 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Why does everyone seem to love perimeter bolt heads? I've heard a lot of people say they think they look better... ? Centerbolts look better to me and seal better, And I dont know about you guys, but every time I see an engine with shiny perimeter bolt valvecovers I always immediately assume it's some 70s truck smogger heads. Does anyone else generally get the same vibe? Or is it just because most aftermarket heads are perimeter bolt and everyone is going for the fancy street/strip car look?
Old Aug 9, 2011 | 12:41 AM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Re: Perimeter bolt heads
I like my new covers.I still need to drill the holes for the pcv and breather though,just a test fit for now.
To the op,I'm not a fan of the centerbolt valve covers because there aren't as many aftermarket ones out there.You can buy the adapters to use perimiter bolt covers on centerbolt heads though.
Old Aug 9, 2011 | 12:59 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Always had problems with keeping gaskets in on old style covers.
Glue gasket to cover , used spreaders ; gasket still managed to dislodge and allow oil to leak out because of uneven clamping on corners especially with tin covers.
With CB style , can R/R cover as many times as you like without leaks because gasket fits in a double sided groove that it can't move from and is clamped evenly around perimeter
But the adapters give you leaks that the centerbolt covers don't have
Old Aug 9, 2011 | 08:09 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I love centerbolts.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
