gauges go crazy while cranking
Old Aug 10, 2011 | 02:29 PM
Snicklfritz's Avatar
so i have an 83 camaro with the 305 crossfire injection i am almost positive it has a ground problem under the dash when you crank the starter the gauges peg to the highest they go and get stuck i have 2 questions has anyone had this problem before and does anyone have ground distribution chart for this year thank you for your time
Old Aug 10, 2011 | 02:47 PM
Re: gauges go crazy while cranking
really no one
Old Aug 10, 2011 | 03:10 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
http://www.nastyz28.com/camaro/wire/78w-rear.jpg
does this help?
Old Aug 10, 2011 | 04:15 PM
No but thank you i have wiring dgrams just dont know where to start lookin for the ground besides for under the dash as i am sure u have seen under there not much room to work with
Old Aug 10, 2011 | 10:53 PM
Touareg's Avatar
Car: 82 Trans Am; 83 Daytona Pace Car
Engine: Crossfire Injection
I would check the connection from the starter to the battery and then to the ignition, everything runs through this metal tube attached to the block/transmission and if a wire breaks down (due to heat) and contacts the tube it will cause this problem.
This happened to me on my 83 I had 13 years ago.
Old Aug 11, 2011 | 09:31 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It's supposed to do that - it's the 'bulb test' function that operates from the ignition switch when you crank. It's meant to let you know that your gauges/idiot lights are working. I think it works on the temp, and maybe oil pressure, and brake gauges/lights.
Of course they are not supposed to stay up there after you stop cranking, so there may indeed be a problem to track down. Sticky pointers maybe?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
Formula_88AE
Sep 3, 2015 01:47 PM
