Help car wont run
Old Aug 23, 2011 | 07:06 PM
notamechanic's Avatar
Car: 90 camaro rs/95 grand cherokee
Engine: 3.1 v6/4.0 straight 6
Help car wont run
Ok...
1990 Camaro RS 3.1L V6
It wont stay running it cranks starts and then either idles horrible for a minute then shuts off or it just starts and instantly turns off. Every once in a while it starts and runs until i turn it off and drives up and down the driveway just fine.
Things i have replaced... getting code 33 even after switching parts
-Throttle sensor
-Idle control
-valve cover gaskets
-ignition module
-fuel filter
-plenum gaskets
-temp sensor
-serpintine belt
-MAP sensor
-a few vaccum lines
-battery
-cleaned the fuel injectors
The fuel pump seems to be working i took the filter off and it shoots out fuel but not sure if its constant enough to keep it running. if i put starter fluid in the intake it runs longer before it idles rough and shuts off.
if anyone can help that would be nice. Its my Girlfriends car and i would like to get it running again.
Old Aug 26, 2011 | 04:35 PM
1killerolds's Avatar
Re: Help car wont run
get a fuel pressure gauge and check the fuel pressure. also, measure the resistance of the fuel injectors to see if you have a shorted injector.
Old Aug 27, 2011 | 05:30 PM
okay will do right after the hurricane is done in a few days.............thanks
Old Aug 28, 2011 | 04:54 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
LOL I've neard all kinds of reasons for not getting to stuff right away...but "hurricane" is a first!
Stay safe man.
Old Aug 30, 2011 | 10:33 PM
The hurricane wasn't too bad lol I checked fuel pressure its at a good 40 psi bought a fuel pressure regulator and of course its held in by 6 saftey torx and the smallest ones possible.upon tightening them they almost all strip no one has them in their store and the dealer wants 30 bucks per screw lmao.
Old Aug 31, 2011 | 09:51 AM
I don't see the reason why you would have to put tamper resistant screws back in. If you can't find any regular screw, let me know. I'm sure I can get some for you. I'll pull one tonight and check the size and thread pitch. I have the engine on a stand anyways.
Old Sep 3, 2011 | 05:26 PM
I checked everywhere no one had the screws I rigged them back in..lol thanks tho. After I got the regulator in it starts more often but still misfired so I changed plugs and wires (plugs were grossly black) and still have the same damn problem.
Old Sep 3, 2011 | 05:37 PM
I thought I would add that I'm about to push this thing out Into the road.
Old Sep 4, 2011 | 04:50 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Have you ohmed across your injectors yet to make sure one or more hasn't gone bad?
Old Sep 4, 2011 | 08:06 AM
I do that by removing the connector and using a multi meter correct?
Old Sep 4, 2011 | 08:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I believe that's how it's done yes. Not sure of the required reading though because I'm running a Carb here so that's not something I need to check. Check the TPI forums or do a search for "ohm injector" and that should come up with something for you.
Old Sep 4, 2011 | 08:30 AM
Ok ill try that next. Hopefully it is not raining when I get done work. Thanks if its not that ill have to check timing you know anything about that?
Old Sep 4, 2011 | 08:40 AM
Ohm testing is easy just gotta do the no rain dance.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
