New starter won't work, w/ new battery
Old Aug 26, 2011 | 07:55 PM
bojangler's Avatar
Howdy. Driving a '92 mitsubishi 3000gt I recently bought. Bought a new battery about 2 months ago, and then I started noticing my starter was jamming so I ordered a new starter and put it in the other day. It didn't work right away (i thought because the gear just needed to wear in a little) so I whacked it and I was good to go. The next time I tried to start my car I just heard a click.
I tried hitting the cog part of the starter and starting it and it worked maybe 2/10 times, but mostly I just hear a click. Checked around the battery and it looks good as far as loose connections go. I did however notice that randomly after one of my attempts at starting it up my sound system was unresponsive...
Now when I hit the cog part of the starter nothing happens, so I tried hitting the solenoid part and I got the engine started maybe 2/10 tries again, and sound system is still not working.
Anyone else had this kind of problem before? Sucks lots lol
Old Aug 26, 2011 | 07:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: New starter won't work, w/ new battery
Shim(s)
Old Aug 26, 2011 | 08:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like a fusible link has blown for stereo.
Starter needs shimmed correctly.
Might have issue with neutral safety switch, ignition switch, or any other part of the ignition wiring.
Not a 3rd gen F-body car, so all we can do is toss 3rd gen F-body car suggestions your way. This board is solely for 3rd gen F-body cars, so this will get locked by a mod. Search net for a board more suited to your needs.
Old Aug 26, 2011 | 08:53 PM
Sounds like you need to get rid of the MissTooBitchy and get a CAR.
Might I suggest, a 3rd gen GM F-body, so you can post about it on this BBS and your thread not get locked or deleted.
Old Aug 26, 2011 | 09:36 PM
Joefuss's Avatar
Car: Camaro RS
Engine: 5.0 TBI
Yeah you need to shim it, plain and simple. look at the way its going, and shim it so it doesnt get locked up n the fly wheel. It takes a bit of practice... speaking from previous attempts myself.
Old Aug 26, 2011 | 09:37 PM
Joefuss's Avatar
Car: Camaro RS
Engine: 5.0 TBI
Btw you will need half shims, which you'll have to cut the full ones in half urself, u prolly need to shim it away from the flywheel but really it just depends on how its getin stuck
3rd gen money
Oct 11, 2019 09:57 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
lanceflame44
Sep 25, 2015 12:28 PM
64goatman
Sep 9, 2015 01:09 PM
