paper clip wtf is it true
Old Sep 1, 2011 | 09:50 AM
jreyes916's Avatar
Car: 89 camaro
Engine: 5.7 from an 89 blazer
can a paper clip read check engine light codes by its blinks
Old Sep 1, 2011 | 09:57 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: paper clip wtf is it true
The paper clip doesn't "read" anything. It grounds the data port terminals causing the Check Engine light to blink. Do a search on this... it's been covered many, many times.
Old Sep 1, 2011 | 10:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
on GM OBDI vehicles, there's no reason to spend money on a code reader (different than diagnostic tool) when a short piece of wire or paper clip will do the trick for much cheaper.
Old Sep 1, 2011 | 12:10 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
GM Check Engine light Codes without a Scan Tool
its all here
Old Sep 1, 2011 | 12:25 PM
JimRockford's Avatar
Originally Posted by z28romance
Thank you! I am going to read this link right now!
Didnt early third gens used to have a feature where you would turn the ingition on and off a certain amount of times and the codes would flash?
Old Sep 1, 2011 | 02:30 PM
I've never heard of that.
Old Sep 1, 2011 | 02:32 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
dodge has that
Old Sep 2, 2011 | 09:30 PM
jreyes916's Avatar
Car: 89 camaro
so its true im gonna check that and what if your check engne light comes on when the car is in drive for a while
Old Sep 3, 2011 | 12:07 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Just a little note. The paperclip works. The wire works. Solder, however, will not work. I had a 1 inch long piece of solder I tried to use once and it did nothing. Thought that was odd although Im sure tehre's a good reason for it.
Night rider327
Feb 25, 2016 09:50 AM
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
