Brake switches and TCC lockup
Old Sep 4, 2011 | 02:12 PM
snoopybg's Avatar
My car has 2 brake switches. The one for the stop lights and the other one for the cruise control.
My question is which one does the ECM monitor to engage the TCC lockup? The one without the vac line has two connectors. Is the two-wires one for the ECM, if not what is it for?
Basically I wanna know if I need the vacuumed switch if I don't want the cruise control.
1987 camaro
Old Sep 4, 2011 | 02:29 PM
snoopybg's Avatar
Re: Brake switches and TCC lockup
Originally Posted by Desert86Roc
But to answer your question....you may not be locking because of a simple wiring problem. Above your brake pedal are 2 switches, one for the brake lights, one for your TCC solenoid / cruise control vacuum release (it is the switch with the vacuum line attached to it).
Is this correct?
Old Sep 4, 2011 | 08:39 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Snoop - The 700R4 trans uses vacuum for lock up of the over drive function of your transmission. The brake switch works to interrupt the vacuum switch mounted next to the brake switch when the brake is applied.
When you hit the brake the system assumes you are stopping and need to downshift so the vacuum switch cuts vacuum to the TCC and drops the trans back into drive to allow proper downshift.
I do not believe the vacuum switch on the brake pedal has any inputs to the cruise control. I believe it is dedicated to dropping the trans out of lock up when you hit the brake.
The vacuum related to the cruise control is underneath the hood located by the steering box on the driver side. It looks like a very large EGR valve with throttle cables and vacuum lines running to it.
If you want lock up overdrive on your transmission, do not mess with the vacuum switch on the pedal. That much I am certain.
Old Sep 4, 2011 | 09:02 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
I thought the 700r4 was locked up electrically from recent study here. I have a trans problem. However I think it's clutches and not lockup. No 3rd or 4th.
I have no vacuum line to my transmission. My th350 did though.
Could someone clarify this.
Old Sep 5, 2011 | 01:16 AM
snoopybg's Avatar
Well, I too did some reading in many other threads that stated the TCC lockup in 700r4 is performed by an electric coil, controlled by a switch on the brake pedal. I only am not sure which switch.
Old Sep 5, 2011 | 03:21 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the 700 has no vacuum controls on it.
the shift points are controlled by the TV cable and the governor.
TCC is electronically controlled by the ECM.
the TCC gets power thru one of the brake petal switches.
i don't have a wiring diagram handy, but i believe one side of the switch with the vacuum hose on it is for TCC, but i could be wrong.
the vacuum part of that switch is a safety to insure the cruise control releases the throttle.
Old Sep 5, 2011 | 09:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by snoopybg
other threads that stated the TCC lockup in 700r4 is performed by an electric coil, controlled by a switch on the brake pedal. .
Correct
Old Sep 5, 2011 | 10:04 AM
snoopybg's Avatar
Thanks a bunch. So the ECM does not monitor this switch, but the switch disengages the clutch directly.
Where do you get these diagrams?
Old Sep 5, 2011 | 10:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As previously noted above ; the ECM operates the TCC by grounding the TCC wire (at ECM).
Obviously when the power supply is broken at the brake switch the TCC solenoid disengages
That is from a GM FSM ( factory service Manual ); the best investment you will ever do if you want to save $$$ on your car
Some more basic diagrams here
http://www.austinthirdgen.org/index.php?pid=19
Old Sep 6, 2011 | 02:36 AM
snoopybg's Avatar
Thank you
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
