Vortec headed 305
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
Vortec headed 305
First of all, a few months ago I decided to rip apart my L03 and put some better heads and a cam in it. I aquired some '062 vortecs, had them shaved .030" and had screw in studs put in. My cam has just a hair over .500" lift. Runs pretty strong!
The problem im having is now with about 1500 miles on it, im starting to burn more oil than ever. Im thinking its because I didn't have the valve guides cut for the extra lift, (didn't know I needed to at the time). I heard that there are spring and retainer combos that I could get that would give me more retainer to guide clearance. Is this true or am I just going to have to bite the bullet, pull the heads and machine them?
Just looking for the next step right now, any help greatly appreciated.
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Re: Vortec headed 305
I had the same problem. But mine was the intake gaskets! I had used the Edelbrocks since I bought a performer EPS intake. Was fine at first then it started using oil like crazy and there was also oil in the tail pipes. Get the original GM gaskets they are a little pricey "70 bucks" but they saved the day.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Engine: 5.3 LM4
Transmission: 4L65E
Very interesting article, so to me it sounds like I could safely use a cam that has .550" lift without modifying the guide at all? correct me if im wrong...
I am still sort of confused how the beehive spring will give me more retainer to guide clearance, I understand that you would have more room before coil bind.
Car: 91 Camaro
I don't know how good the Fel Pro's are but I torqued the intake per the patern at the correct torque and it still leaked. When I took off the intake you could see the gasket soaked with oil! Not to mention the intake port had oil in it also. My first hint was the spark plug was fouled with oil. That made me nervous because it was a new engine from GM (96-99 truck engine) but I read a few articles on those aftermarket vortec intake gaskets leaking. It's been a year and a half and the GM's are just fine.
Engine: 5.3 LM4
Transmission: 4L65E
That is a possibility, I am still worried about having an issue with guide clearance, anyone one else out there run into this problem?
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Interesting, are those steel retainers? Would titanium retainers generally give you even more room?
Engine: 5.3 LM4
Transmission: 4L65E
Well I filled the shopping cart, think Im gonna do a compression check first before I buy. Would suck if the problem is the rings or something.
Bad rings would smoke all the time though right?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I went with LS6 springs and comp retainers. There was no way I could get to .550 I even didnt try to go to .525 because the tolerance was too tight for my liking.
If you pull the heads for some reason, do it right and have it machined. You should have had new guides installed and machined to the correct height in the first place. I would have done that the same time you had the screw in studs installed.
Engine: 5.3 LM4
Transmission: 4L65E
But since it is all together now, I was looking for alternatives to pulling it all apart again. lesson learned I suppose.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
