oversized oil pan
Old Sep 12, 2011 | 07:13 PM
bitchin84's Avatar
Car: '84 Z28
Engine: SBC 5.7L/350CI
Axle/Gears: stock
oversized oil pan
hey guys, i picked up an 84z28 supposedly swaped in 350 out of an 88 truck.
havent had time to get the block casting numbers to make sure but when i got it i had some lowering springs sitting in my garage so i put those on and now i noticed the lowest thing on my car is my oil pan... not even 2 inches from the ground. and i didnt even lower it thaaat much. about 1.75in front and 1.5 rear. it shouldnt be this low should it?? i got 9 inches from the block to the lowest part of the pan.(the rear) i have another one that measures 7in i believe and when i tried installing it the part that scoops up the oil hits the bottom of the pan. (it also measures almost 9 inches from the block). what is that part called and can i just swap both with ease?
ill try to get some pics soon and any help is appreciated. thanks
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
