Choke Will Not Stay Closed
Old Sep 18, 2011 | 07:12 PM
SpecialEditon84's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: Pontiac 2.8 L V6
Transmission: Automatic 4spd
Axle/Gears: Stock
It is just starting to get cold as Winter comes around the corner. I own an Electric choke for my 1984 Firebird and it will not stay closed. It is always open even when it is cold outside. We just dropped in a new fuel pump because it is not idling right. Any suggestions?
Old Sep 18, 2011 | 07:25 PM
Damon's Avatar
Re: Choke Will Not Stay Closed
What kind of carb? They are usually adjustable by loosening the screws and rotating the choke element. But if the choke element coil pigtail (some models of choke element) is not on the lever pin inside, it won't work.
Old Oct 6, 2011 | 02:48 PM
Axle/Gears: Stock
I really dont know what kind of carb it is. It is a rochester.
Old Oct 6, 2011 | 02:49 PM
Axle/Gears: Stock
Also mine is riveted and from the factory that way.
Old Oct 7, 2011 | 08:38 PM
Damon's Avatar
The factory riveted them in place in many cases. They didn't want people adjusting it. Also, some chokes have an "index key" so it can only fit in the housing one way- no adjustment by rotating it, even if it had screws you could loosen.
They sell aftermaket replacement choke elements that (sometimes) come with self-tapping screws to replace the factory rivets. In other cases they come with replacement rivets that you install using a common hand-held "pop rivet" gun.
Old Oct 8, 2011 | 03:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
replace the electric choke, they don't last forever.
Old Oct 8, 2011 | 08:08 PM
ex-x-fire's Avatar
Is that a factory Pontiac 400 twin turbo in your 84 s/e?
Old Oct 18, 2011 | 06:38 PM
Axle/Gears: Stock
It is not. I'm getting rid of it because its way to much gas for a daily driver so I'm rebuilding the factory V6
Old Nov 8, 2011 | 04:15 PM
Axle/Gears: Stock
please help!
Old Nov 8, 2011 | 05:51 PM
ex-x-fire's Avatar
Did you follow any of the above advice? If you did then speak up.
Old Nov 10, 2011 | 04:42 PM
Axle/Gears: Stock
No there not rivited and its going to be a showcar. I'm not changing it to a holly.
db057
Apr 28, 2019 07:45 AM
bbsr72
Apr 2, 2016 09:12 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
corey8084
Sep 17, 2015 02:56 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
