Did an electric fan come standard in the 1992 Camaro RS LO3 5.0?
Old Sep 22, 2011 | 12:46 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I just realized I have an electric fan in my 92 RS 5.0. Did that come standard or was that custom installed? Thanks guys.
Old Sep 22, 2011 | 02:14 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Did an electric fan come standard in the 1992 Camaro RS LO3 5.0?
It came standard i believe because my car also has an electric fan
Old Sep 22, 2011 | 11:19 AM
Car: 1992 Camaro RS
That will def help me. I plan in going with an open air element and here in Houston there is going to be alot of hot air getting sucked in. I dont want it to bog down in traffic.
Old Sep 22, 2011 | 06:56 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
They were all electric as is mine. I'd rethink the open element idea though. What does the fan have to do with having an open element?
Old Sep 23, 2011 | 12:13 PM
Car: 1992 Camaro RS
With an open element more warm air will be being sucked into the engine, and that bogs down the engine if it's just sitting in traffic sucking in hot air. An elecric fan helps bring in a little more cool air.
Old Sep 23, 2011 | 01:16 PM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
The electric fan will bring in nice hot air through the radiator/condensor. I'd recommend rethinking the open element as well.
Old Sep 23, 2011 | 03:12 PM
If you really want to benefit from an open element, you would need to have a scoop, or a raised cowl hood.
Old Sep 23, 2011 | 08:27 PM
Car: 1992 Camaro RS
There are better ways to do cold air induction. Like using a supercharger hat and some tubing plus a K&N filter. But that's expensive, not to mention a waste of time. Total cost of an open air filter $25-30, the way it looks under the hood, priceless. well not priceless. I don't know if any of you have seen my hood, but I can guaranty you it won't be replaced or modfied any time soon.
Old Sep 23, 2011 | 11:09 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
If you want some performance gains i say you just buy air cleaner assembly from a 305 H.O.
Old Sep 24, 2011 | 07:09 PM
Car: 1992 Camaro RS
Hard to find, more expensive, and doesn't work well for mine cause there's junk in the way where the second snorkle would go.
Old Sep 24, 2011 | 08:29 PM
You can find a duel snorkle in rick's camaro. Also that junk can be relocated if you want to install one.
Old Sep 24, 2011 | 09:26 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
TBI Cold air intake on Ebay, less than $50
http://motors.shop.ebay.com/fuzionma...911.m270.l1313
Old Oct 5, 2013 | 01:14 PM
Biggd4355's Avatar
yes
Old Oct 5, 2013 | 01:17 PM
Biggd4355's Avatar
your fan brings hot air in thru the radiator, hotter than the outside air.
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
