92 3.1 RS wont start
Old Sep 22, 2011 | 04:38 PM
Zimmerser's Avatar
I am going crazy trying to figure out why my car wont start.
First the fuel pump was bad so I replaced it. Now I have fuel to the engine within specs. Then I checked the plugs, wires, icm, dist cap, rotor, ignition coil, and pick-up coil. The only thing that was bad was the pick-up coil. Injectors ohm correctly (12.3-12.6), and proper voltage to each. Battery is ok, alt is ok, starter is ok. Checked the timing and its 10* BDTC on 1.
The engine turns, but it won't start. I do not see the check engine lights on. I do notice the oil pressure gauge and the temp gauge going from 0 all the way to the right when trying to turn it over.
The next thing I am going to try is a compression test, but I do not think it is necessary since the car ran fine before I parked it 2 years ago.
What am I missing??
Old Sep 22, 2011 | 04:42 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Re: 92 3.1 RS wont start
did you make sure to see if it had spark
Old Sep 22, 2011 | 04:55 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Just because the injectors pass the ohm test doesn't mean they're not clogged. If the car sat for 2 years it's a possibility. But you need a spark and you could try starting with starting fluid sprayed in the intake while someone cranks it. That'll give you a clue to the spark/fuel situation.
Old Sep 22, 2011 | 05:07 PM
Zimmerser's Avatar
Yes, I have a spark tester and all plugs have good spark. I sprayed some carb cleaner in the intake (it was all i had on hand) and nothing happened.
Old Sep 22, 2011 | 05:10 PM
Car: 1988 TransAm
Axle/Gears: stock
there is some thing causeing it not to fire over tho remeber air fuel spark is all thats needed for a engine to run
Old Sep 22, 2011 | 06:18 PM
Zimmerser's Avatar
I know, but I can't figure it out and it is killing me. I think I'm going to take the upper off tomorrow and see if the injectors are clogged. I have nothing else...
Old Sep 22, 2011 | 06:23 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Try a little bit of gas thru the TB. You need 3 things, spark, fuel and air. Sounds like you have spark and air. If it runs for a second or two with a bit of gas then its time to track down why it's not delivering fuel. If thats the case then the first thing I would check is fuel pressure.
Old Sep 22, 2011 | 09:39 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Get someone else to crank the engine and spray starting fluid right into the TB. It takes a fair amount. If you get no fire then you aren't getting a spark. At least not at the right time. You may want to try this before you pull the injectors.
Old Sep 24, 2011 | 07:23 PM
Zimmerser's Avatar
I think its a timing issue. It will run but only when I rev it. I also discovered the o ring in the throttle body is bad and it leaks coolant. Does anyone know the part number for it?
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
