bent valve ????
Old Oct 5, 2011 | 01:25 AM
86Stevo's Avatar
bent valve ????
okay heres the deal i am putting in a cam in my motor thought the cam was wiped out because id adjust the valves it would pull real strong for like 3 weeks and then back to being weak on the top end again so im replacing it with a bigger cam that i no is good (comp cam xe268 12-242-2)
my concern is that when i was lining up my timing marks i was turning the motor over with out the push rods in so the valves weren't moving
but i was getting a hissing noise coming from the back of the motor is this something els i can be hearing in the motor like air escaping from a piston coming on the down stroke ? or should i save for new heads or new valves because ones bent???
Old Oct 5, 2011 | 03:25 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: bent valve ????
Its normal to have some hissing when turning the motor over. Its due to air escaping past the rings. If its a real fast sort of whooosh sound from one cylinder as you turn the engine over, than it may be a sign of something worse. A compression test may tell more, but a leak-down test will tell for sure if the engine is loosing significant compression in a cylinder.
Old Oct 5, 2011 | 10:11 AM
86Stevo's Avatar
Re: bent valve ????
ok forgot about the gap in the rings
its loud but i have to turn the motor slow or els its really hard to turn from the compression
thanks was making the me nervous there for a little bit
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dbrochard
Sep 7, 2015 09:41 AM
