Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Old Jul 30, 2012 | 11:16 PM
  #51
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Re: Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Originally Posted by PhoenixFirebird
Firebirds have battery mounted on the driver side, and purge canister on the passenger. Camaro's are backwards. Great GM logic lol.
Or are the Pontiac's backwards?
Old Aug 1, 2012 | 01:52 PM
  #52
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Well I have a Firebird, so of course the Camaro is backwards
Old Aug 1, 2012 | 02:14 PM
  #53
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Haha. Funny that I got all these vacuum diagrams out of a "82-92 Camaro Handbook". Go figure. Hahaha
Old Aug 6, 2012 | 04:25 PM
  #54
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Does anyone have diagram for the cruse control on a 92 305 tbi?... my cruze control line seems to be "Y'd" off of the MAP sensor vacume line it just dont seem right.
AND a diagram for the ball thats under the Charcoal Canister.... my vacume line that splices off my MAP vaccume line runs to my cruze control and Ys off to that ball under the charcoal canister... it cant be right!
Old Aug 6, 2012 | 06:29 PM
  #55
NEFbody's Avatar
Car: 1992 GTA
Engine: L98 T.P.I. Stock
Originally Posted by Chevy86 IROC-Z
X3.
X4
Old Aug 7, 2012 | 01:06 AM
  #56
I may have it in my 1990 GM shop manual. I'll get back to you tomorrow with an answer. If I do find it (which I will), I'll pm you with a new thread. Don't wanna stray away from the main vac. line topic.
Old Sep 1, 2012 | 09:27 PM
  #57
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
Transmission: 5 speed
the one that goes to the inlet manifold where is the inlet manifold ??
Old Sep 1, 2012 | 11:24 PM
  #58
Can you be a little more specific?
Old Sep 1, 2012 | 11:31 PM
  #59
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
The diagram says it comes out the canister it had 2 or 3 other hoses and it connects to the inlet manifold , where do I connect it to the inlet manifold back front side top left right side ?? Lost confused
Old Sep 2, 2012 | 12:21 AM
  #60
Okay bro. I am more than willing to help you out. But there are about 25 different diagrams man. If your on a pc, right click the opropriate picture, copy it, then paste it in a new post below. Then I'll know which vacuum line your troubleshooting.
Old Sep 2, 2012 | 12:28 AM
  #61
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
It's a 2.8 Camaro big dawwg! Duno how to post pic but it's at beginning of this thread
Old Sep 2, 2012 | 09:55 AM
  #62
oneoldman's Avatar
Car: 87 camaro/ 67 chevelle
Engine: 2.8l / 283 V8
Transmission: 700r4 / saginaw 4 speed
Axle/Gears: 3.42 / 3.08
None of the diagrams I've seen answer my question. I have an 87 Camaro 2.8L mpfi the double vacuum port on rear of upper plenum I know the large side goes to the brake booster I have a hose from the vacuum cannister in left front fender and a small very short plastic line from firewall at the a/c heaterbox area. I need to know what type of connector marries the saller port on the plenum to these other two lines that I think are for the heater controls. The car was disassembled when I bought it.
Old Sep 2, 2012 | 01:03 PM
  #63
Well the best way to know what and how to connect the lines is by posting on the general engines threads. Copy the vacuum line picture and make a post with your question. Then when someone with the same engine sees your question, they may help you out. You gotta remember that I posted these pictures to help out the community. I only have a 86 IROC, TPI. So I don't know every other engine by heart other than mine. Please do use the diagrams as guides.
Old Sep 2, 2012 | 01:05 PM
  #64
There may be a splitter or a check valve. I'm not sure but that's the best answer I can give. Perhaps you can copy the diagram that best suits your engine and make a tread under the general engine thread.
Old Sep 23, 2012 | 09:58 PM
  #65
John DeMoss's Avatar
'89 2.8L Camaro injected 700 auto
Old Sep 23, 2012 | 10:45 PM
  #66
Did you search the first page of the thread? Should be there.
Old Oct 6, 2012 | 09:51 AM
  #67
porkbuttman2204's Avatar
I have a 82 z28 with 4 barrel carb 5.7L engine and TH350 trans ignition is electronic not vacuum advance it also has smog setup I sure would like to have diagrams for the emission and smog lines. Thanks for any help you can give.
Old Oct 6, 2012 | 01:16 PM
  #68
Is that factory?
Old Oct 9, 2012 | 06:12 AM
  #69
Is that factory?
I think it is.
Old Oct 9, 2012 | 11:35 AM
  #70
I don't think it is unless someone else proves me otherwise. All combinations that are listed are from a good source. If you can trace back the PO, maby they can shed some light. Other than that, your best bet would be to look at a similar set up that closely resembles your set up on page 1.
Old Nov 16, 2012 | 08:20 PM
  #71
m1911a2's Avatar
Good day gentlemen, is there somebody out here who have a vacuum diagram for a Toyota 2E?
Old Nov 17, 2012 | 06:09 AM
  #72
Try a Toyota forum. Notice that all the diagrams I provided are for Camaro's.
Old Nov 17, 2012 | 06:14 AM
  #73
m1911a2's Avatar
yes sir i do notice but because of my desperation, am taking my chances that somebody out here might know about my need.
Old Nov 17, 2012 | 08:59 AM
  #74
Sorry man. I only have service manuals that display Camaro stuff from 82-92.
Old Nov 17, 2012 | 08:30 PM
  #75
m1911a2's Avatar
Lastly Sir, are you familiar of Aisan carburetor?
Old Nov 17, 2012 | 08:43 PM
  #76
Sorry man. I have never heard of that carb.
Old Nov 17, 2012 | 09:09 PM
  #77
m1911a2's Avatar
Thank you for your time Sir.
Old Nov 17, 2012 | 09:51 PM
  #78
Old Jan 11, 2013 | 04:15 PM
  #79
apollo68's Avatar
Do you have the diagram for a 88 firebird 5.7 tpi 350?
Old Jan 11, 2013 | 09:08 PM
  #80
Post number 17 my friend.
Old Jan 11, 2013 | 09:45 PM
  #81
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Toyota
Old Feb 6, 2013 | 01:14 AM
  #82
thetriplet's Avatar
can you send me a diagram for 87 5.0l 305 carb be much appreciated
Old Feb 6, 2013 | 01:17 AM
  #83
Okay man. All you gotta do is look in the previous pages.
Old Feb 7, 2013 | 07:01 PM
  #84
gdwrnch's Avatar
Car: 1987 Iroc
Engine: 5.0
I just collected ALL vacuum lines from 82 - 92 TG F-Bodies!!!! If anyone needs one, drop a line requesting one (along with year, model, engine size, and tranny) and Ill post it up as soon as possible. Models covered with vacuum lines are:
1982-1984 2.5L TBI
1985-1986 2.5L TBI
1982 2.8L CARBURETED
1983 2.8L CARBURETED
1984 2.8L CARBURETED; EXCEPT CANADA
1984 2.8L CARBURETED; CANADA
1985 2.8L FUEL INJECTED
1986-1989 2.8L FUEL INJECTED
1990-1992 3.1L FUEL INJECTED
1982 5.0L CARBURETED
1983 5.0L CARBURETED
1984 5.0L CARBURETED; EXCEPT CANADA
1984 5.0L CARBURETED; CANADA
1985 5.0L CARBURETED; EXCEPT CANADA
1985 5.0L CARBURETED; CANADA
1986 5.0L CARBURETED; EXCEPT CANADA
1986 5.0L CARBURETED; CANADA
1987-1988 5.0L CARBURETED
5.0L CROSS-FIRE FUEL INJECTION
1988-1992 5.0L THROTTLE BODY INJECTION; MANUAL TRANSMISSION
1988-1992 5.0L THROTTLE BODY INJECTION; AUTO TRANS.
1985-1986 5.0L TUNED PORT INJECTION
1987-1989 5.0L AND 5.7L TUNED PORT INJECTION
1990-1992 5.0L AND 5.7L TUNED PORT INJECTION
87 5.0 TPI, thanks
Old Feb 7, 2013 | 07:39 PM
  #85
Old Mar 2, 2013 | 09:43 PM
  #86
bpfcam's Avatar
Just wanted to say thanks for posting these.
Old Mar 2, 2013 | 09:47 PM
  #87
No problem man. I tried to make it a sticky, but it is not up to par I guess.
Old May 20, 2013 | 10:06 PM
  #88
jedrom's Avatar
Car: 1989 IROC-Z
Engine: 350 Jasper
Hey man, hate to bring up a dead thread, but could you hook me up with a few of these? My car's kind of a hackjob from the previous owner. Could you hook me up with vacuum diagrams for an '89 5.7 TPI, '90 5.7 TPI, and an '89 TBI?
Old May 21, 2013 | 08:28 PM
  #89
Before I get anymore requests about a diagram, go to page 1 and
Old May 22, 2013 | 12:29 AM
  #90
jedrom's Avatar
Car: 1989 IROC-Z
Engine: 350 Jasper
Got it, thanks man
Old May 28, 2013 | 03:55 AM
  #91
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
The 82 5.0L Carb diagram is WRONG. I would follow the 83 diagram for an 82 as 82s came with a VAC Sensor and do not have any vacuum sources on the distributor. Also the vacuum line to the Air Cleaner is not on the back of the carb, rather should be like the 83 on port B in front. The VAC Sensor should be connected in back with the hard plastic tube.
Old May 28, 2013 | 09:28 PM
  #92
IROC-BOB86's Avatar
Car: 86 Iroc-z, 2011 BMW, 13 Pilot
Transmission: 5 Speed
thanks i have been looking for this for my 86 305 carbureted iroc. just one thing thou my 86 air filter only has one snorkel on it. is this right?
Old May 28, 2013 | 09:47 PM
  #93
Ok "KnightmareCS". Take your concerns to GM, which is where I got these diagrams. Have a GOOD DAY.
Old May 28, 2013 | 09:49 PM
  #94
Good question man. I have no idea.
Old May 28, 2013 | 10:22 PM
  #95
Car: 82,83,99 T/As
Engine: 350,350,383
Sorry, my frustrations weren't toward you. It was to the incorrect diagrams for 82.
These are the same diagrams seen in ALLDATA, Autozone, Chiltons, etc.
Unless, of course, they're for some weird California/Canada cars. Anyways, can't seem to find one for a regular ol 5.0.
Old May 28, 2013 | 10:26 PM
  #96
Old Jun 1, 2013 | 12:01 PM
  #97
Chad85T/A's Avatar
Car: 85 T/A
Thanks for posting these. It's been a great help to me!
Old Jun 17, 2013 | 10:57 PM
  #98
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Thank you for posting these. I would love to see an actual pic of where the vacuum line comes from the charcoal cannister under and to the throttle body.
Old Jun 17, 2013 | 10:59 PM
  #99
Which side is your canister?
Old Jun 17, 2013 | 11:00 PM
  #100
And for the last two members, your welcome.
