Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Old Feb 16, 2016 | 10:53 PM
  #201
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
Re: Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Do you have photos of the actual hose routing from the canister to where they connect to? My 88 gta 5.7tpi canister with 2 connectors coming from it. One going into the control valve, with the control valve with 2 connectors coming from the side. one connector goes to a thin hard black line which I guess goes to fuel tank. Where does the other connector go to?
The schematic shows a hose connector coming from the bottom of the control valve with hose going back into the hose coming from canister to control valve. My control valve has no hose connector under it. Both connectors are on the top on side pointing out.
Also what size is the other hose coming from canister to throttle body? Is the end coming from canister smaller then the other end going to throttle body?
I am asking cause I disconnected them a long time ago, misplaced photos I took so now I can't figure out how they go. Yes that means I SNAFU'd. I have photos of the canister and connector if some one needs to see them.
Unless I can find another 5.7 tpi gta here in san antonio to compare to, then I would be ok.
Any help out there? Thank you
Old Apr 28, 2016 | 11:44 PM
  #202
lisa4275's Avatar
92 chevy truck vacuum hose diagram
Old Apr 28, 2016 | 11:52 PM
  #203
lisa4275's Avatar
92 chevy truck vacuum hose diagram please
Old Apr 29, 2016 | 06:37 PM
  #204
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Wrong forum. I only have Camaro diagrams. Sorry.
Old Apr 29, 2016 | 06:39 PM
  #205
I don't have any pictures. Sorry.
Old Jul 26, 2016 | 08:58 PM
  #206
Chris49423's Avatar
I need the vacuum diagram for a 1987 Pontiac firebird 5.0 carbureted kinda lost on the quadrajet setup thank you
Old Jul 26, 2016 | 10:34 PM
  #207
Look on the first page bro. All the diagrams are there.
Old Jul 27, 2016 | 12:14 PM
  #208
aroto's Avatar
Car: 1984 Camaro Berlinetta
When you get a chance both 1984 5.0L ones thanks
Old Jul 28, 2016 | 02:02 AM
  #209
Look on page 1. It has all the vacuum lines that I have.
Old Aug 4, 2016 | 09:16 PM
  #210
Meghansmom's Avatar
Vacuum diagram for 1991 S10, 2.5?
Old Aug 5, 2016 | 09:48 AM
  #211
3rd Gen F Body only.
Old Feb 21, 2017 | 04:53 PM
  #212
Victory91's Avatar
f990-1992 3.1L FUEL INJECTED[ i need diagram to know where lines go and if im missing any
Old Apr 3, 2017 | 02:20 PM
  #213
snowbrder124's Avatar
1987 5.0 TPI diagram please.
Old Apr 3, 2017 | 08:54 PM
  #214
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
Thank you all. I followed the link to the diagram and all is copacetic.
Old Apr 24, 2017 | 07:32 PM
  #215
milhouse89's Avatar
Car: 1989 Camaro I-ROCZw/T-Tops
Engine: 5.7L
Transmission: 700-R4
I just lost a long paragraph with parts #'s and description and now you are offline. I'll keep this one short. I have a 1989 IROC-Z w/ TPI and a 5.7L. The car has Edelbrock Aluminum Heads #60859 and Hedman headers. I need head, intake, and Exhaust gaskets. I've narrowed it down to a few choices but I am still unsure as some of the items I need are discontinued. Here is what I have found: cyl. head: Edelbrock #7310 or Fel-Pro #HS 7733PT-15(head gasket set w/Perma-Torque) or gm#-10159409. Intake manifold: Fel-Pro #MS930351. Please feel free to recommend the correct gaskets. also any opinions on the Perma-Torque or MLS or composite gaskets for Aluminum heads w/ a cast iron block. Are the gaskets for the 5.7L and the 5.0L the same? I'm going to send this before I lose it. The car has a stock intake manifold. Thanks for any help.
Old Apr 24, 2017 | 08:33 PM
  #216
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
milhouse89, to whom are you directing the message to? The thread is about vacuum lines for a 5.7l. Not sure if you will get your answer to your gasket questions on this thread but hopefully someone will come thru. good luck
Old Apr 24, 2017 | 09:46 PM
  #217
milhouse89's Avatar
Engine: 5.7L
Yea, I thought I was doing a private msg to eseibel67 but I am no computer expert. I've tried 4 times now and I am getting really tired. My last attempt was an e-mail and I don't think he got that because I'm not sure if this site has my e-mail. I wanted to e-mail because I need this done yesterday. I might try a pm. If you want to do me a solid send the above paragraph with all the gasket part #'s to eseibel67. Thanks man.
Old Apr 24, 2017 | 10:23 PM
  #218
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
Sent him your msg with your member name. hope he answers you
Old May 18, 2017 | 06:30 PM
  #219
seaofnoise's Avatar
Car: 1985 Trans Am GTA
Engine: 5.0
Thanks for taking the time to upload these!
Old May 22, 2017 | 08:55 PM
  #220
rufaast's Avatar
Car: 88 IROC Z
Engine: temporarily stock
Axle/Gears: Stovk
Do you have a schematic for the vacuum lines that are attached to the HVAC dash controller for a 1988 IROC 5.7L , lines inside the car?
Thank You
Derek
Old May 27, 2017 | 12:43 AM
  #221
NoEmissions84TA's Avatar
84 Trans Am 5.0L "H" auto.
I'm going to a mechanical advance distributor and M4ME quadrajet carb.
I'm removing the air pump, air management, EFE & EGR. But I am keeping the charcoal canister with its CCV and Purge TVS.
Do you have any export (non-CCC) diagrams?
Attached is what I came up with - 2 different versions for connecting the CCV. My car's original diagram is XJW.
Edit: A big thanks to T.L. for double-checking this M4ME diagram. There was an error which is corrected now.
Attached Thumbnails Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!-ycm-alternate-ccv-connection.jpg
Last edited by NoEmissions84TA; Nov 7, 2019 at 05:16 AM. Reason: Cleaned background of diagram.
Old Jun 3, 2017 | 05:00 PM
  #222
Amber Warren's Avatar
I need the vacuum hose diagram for a 92 chevy Silverado c1500 v8 305 engine
Old Jun 4, 2017 | 05:33 AM
  #223
babyelephant's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Thanks for sharing these diagrams, I found exactly what I needed.
Old Jun 4, 2017 | 10:48 PM
  #224
I still need 1984 5.0L CARBURETED; CANADA, please.
Old Jul 11, 2017 | 01:51 PM
  #225
bornagainyank's Avatar
Car: 1990 camaro RS 305 auto
Engine: small block 305
Transmission: automatic
Hi, do you have 1990 5.0 tbi please?
Old Jul 11, 2017 | 11:41 PM
  #226
PLEASE. You list in the 1st post, but there is nothing to click on.
Old Jul 12, 2017 | 04:07 PM
  #227
milhouse89's Avatar
Engine: 5.7L
Thanks for replying.
Old Jul 20, 2017 | 07:54 PM
  #228
rnunez89tpi's Avatar
Car: 1989 Firebird
Axle/Gears: Posi 3.23
I’m new to this. Why is it that i can’t see the pictures of the diagrams? Need vacuum diagram for 1989 firebird.
Old Jul 20, 2017 | 07:57 PM
  #229
Car: 1989 Firebird
I’m new to this.
Need diagram for 1989 Firebird 305 tpi. Why is it that I can’t see images/pictures on the site? Thanks!
Old Jul 20, 2017 | 08:00 PM
  #230
Car: 1989 Firebird
Originally Posted by Chevy86 IROC-Z
Why can’t I see the pic?
Old Jul 21, 2017 | 05:36 PM
  #231
charlie66's Avatar
Hi, I need the vacuum diagram for a 1983 chevy k5 blazer 4x4 with a 350 v-8 4 barrel. Do you have that?
Old Jul 25, 2017 | 10:19 AM
  #232
vincevs's Avatar
Car: 1982 Trans Am
Engine: 305 with a cam swap
I see it written out in the first post but how do I download the file?
Looking for 1982 Trans Am 5.0L
Old Jul 25, 2017 | 08:51 PM
  #233
ConnerM's Avatar
Car: 1984 Camaro Z28 T Top
Engine: 350 30 over with 383 stroker kit
Axle/Gears: 10 bolt 3.42gears
I just collected ALL vacuum lines from 82 - 92 TG F-Bodies!!!! If anyone needs one, search below on this 1st page. Models covered with vacuum lines are:
1982-1984 2.5L TBI
1985-1986 2.5L TBI
1982 2.8L CARBURETED
1983 2.8L CARBURETED
1984 2.8L CARBURETED; EXCEPT CANADA
1984 2.8L CARBURETED; CANADA
1985 2.8L FUEL INJECTED
1986-1989 2.8L FUEL INJECTED
1990-1992 3.1L FUEL INJECTED
1982 5.0L CARBURETED
1983 5.0L CARBURETED
1984 5.0L CARBURETED; EXCEPT CANADA
1985 5.0L CARBURETED; EXCEPT CANADA
1985 5.0L CARBURETED; CANADA
1986 5.0L CARBURETED; EXCEPT CANADA
1986 5.0L CARBURETED; CANADA
1987-1988 5.0L CARBURETED
5.0L CROSS-FIRE FUEL INJECTION
1988-1992 5.0L THROTTLE BODY INJECTION; MANUAL TRANSMISSION
1988-1992 5.0L THROTTLE BODY INJECTION; AUTO TRANS.
1985-1986 5.0L TUNED PORT INJECTION
1987-1989 5.0L AND 5.7L TUNED PORT INJECTION
1990-1992 5.0L AND 5.7L TUNED PORT INJECTION
1982 camaro 6.0L CARBURETED
Old Jul 25, 2017 | 08:57 PM
  #234
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Did the thirdgen camaro ever have a 6.0L from the factory?
Old Jul 25, 2017 | 09:03 PM
  #235
ConnerM's Avatar
No but I have a 350 it's been bored 30 over with a 383 scat stroker kit just need wiring and hose diagrams
Old Jul 25, 2017 | 10:05 PM
  #236
zed-028's Avatar
From what i can tell the 82 never came from the factory with a 350 either. If its a transplant, go find the year of the motor itself, then look for the diagrams.
or look for the 82 with the 5.0 - and match the hosing up from there.
Old Jul 28, 2017 | 11:01 AM
  #237
vincevs's Avatar
Car: 1982 Trans Am
I can't get the link to work for the 82 5.0L... any chance you could send it in a PM?
Old Jul 29, 2017 | 03:00 PM
  #238
1988-1992 5.0L THROTTLE BODY INJECTION; AUTO TRANS if you can please.Thanks
Old Jul 30, 2017 | 07:59 PM
  #239
zed-028's Avatar
https://www.thirdgen.org/forums/tech...al-sticky.html
Old Aug 5, 2017 | 10:01 AM
  #240
Shakenblake's Avatar
Car: 1988 camaro iroc z
Any thoughts on what this connect too ? 1988 305 tpi its connected to the line that goes into the passenger side throttle body
Old Aug 5, 2017 | 06:48 PM
  #241
Open the link at post #239 and you will find this diagram.
I don't have TPI myself, but the connection in your picture has to connect to a vacuum source.
Attached Thumbnails Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!-88-305-tpi.jpg
Old Aug 5, 2017 | 08:36 PM
  #242
Okay. Thanks after looking I'm pretty sure it goes to a "T" fitting into the line that goes under the throttle body. Thanks
Old Aug 11, 2017 | 09:35 AM
  #243
walnikj's Avatar
Car: 88 Iroc
Engine: 5.7 tpi
I have a similar set up. But I don't have a valve in the hose coming from the gas tank. Should I? And the diagram has no valve going to the intake.
Old Aug 26, 2017 | 09:10 AM
  #244
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Good morning, First of all, I am sure that I speak for all of us, Thanks for your hard work. I printed out what I need. It'll help me to finish my 305/350 swap. I was wondering if you could find it in your heart to post sensor diagrams for 1986 5.0L 305 TPI and 1990 5.7L 350 TPI. I would like to finish up the wiring re-route within this next week and get the rest of the mechanical done. I haven't heard my 86 IROC run for a year. I am still running all the smog and stuff as well to keep it looking stock. "Sofakingdom" helped me immensely on my engine mechanicals, so I have the .502 grind cam and all the comp cam goodies on it that he prescribed. Also have a nice performance cat that is a 1/4 of the size of the stock one, 3" the rest of the way back to a flow master system.
Old Feb 1, 2018 | 07:05 PM
  #245
81 sea10's Avatar
Anyone got a diagram for a 81 c10 with a 305? Thanks
Old Feb 1, 2018 | 07:11 PM
  #246
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why would you think to look for vacuum diagrams for a truck on a f body forum !
Old Feb 22, 2018 | 06:32 PM
  #247
Mrproblemsolver's Avatar
I have 1988 camaro iroc and it’s a 5.7 fuel injector . I can’t find a diagram for the vacuum lines for inside the car and can you help me please
Old Feb 26, 2018 | 05:19 PM
  #248
zed-028's Avatar
post #239
Old May 21, 2018 | 04:33 PM
  #249
TR1CKY's Avatar
could i please get 1984 2.8L CARBURETED whenever you can. ive been looking all day
Old May 21, 2018 | 06:45 PM
  #250
zed-028's Avatar
again... post #239
