car won't shut off immediately
Old Oct 25, 2011 | 03:21 PM
wranglaro86's Avatar
Car: 1986 camaro z28
Engine: gm goodwrench 350 300 hp
Transmission: 5sp
Axle/Gears: stock
having an issue with my car continuing to run after i turn key to offf position.
After a few seconds it wants to shut down but it just seems like there is something trying to keep it going i guess its still getting spark should i change out ignition switch?
i did just change my alternator and spark plugs and wires not for this reason but because they were bad and yes car was not shutting off prior to these fixes
any ideas?
Old Oct 25, 2011 | 03:39 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: car won't shut off immediately
Carbed?? Or efi??
Is your timing set correct??
Any vacuum leaks???
What rpm is your idle set to...
Old Oct 25, 2011 | 04:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by wranglaro86
... it just seems like there is something trying to keep it going i guess its still getting spark...
Dollars to donuts it's a carb'd car.
It's really rough after turning off the ignition, right? If so, no, it's not still getting spark. It is still getting fuel, though, and hot spots within the combustion chambers are igniting the fuel/air mixture that is still flowing through the engine.
Usually when this happens there are either excessive carbon build-up in the chambers, or really rough castings that are getting hot and staying hot enough to continue to ignite the fuel/air. Often this is accompanied by a poor tune, with excessive ignition advance, and/or excessive carb idle opening. Sometimes running a product like Sea Foam through the engine will clean things up and stop the problem. But, make sure everything is set to factory specs first (timing, idle speed, idle mixture, etc.).
Old Oct 25, 2011 | 04:34 PM
Transmission: 5sp
Axle/Gears: stock
Yea its carb 1986 z28 lg4
Old Oct 25, 2011 | 06:22 PM
Transmission: 5sp
Axle/Gears: stock
I have to check timing and idle speed but I guess it wouldnt hurt to use sea foam to clean out some carbon right?
specialized
Jun 18, 2022 09:26 AM
ZsTransAm
Aug 11, 2015 07:30 PM
hokis
Aug 9, 2015 03:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
