Key and ignition cylinder got STUCK while the car was ON and it kept trying to start.
Old Oct 31, 2011 | 07:33 PM
FooFighters92's Avatar
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
So basically, you know when you start your car and it starts, and you accidentally turn the key a little too long while the car is started and it makes that loud grinding noise? Okay well my car did that and the whole ignition/cylinder was stuck in that position and wouldn't move. It made that grinding noise for roughly 5 minutes before I got it to stop. The car was over red lining on the temp gauge, coolant started boiling. And obviously it wasn't the key that was stuck, it was the cylinder that turns. I disconnect the battery and alternator and kill the car. With lots of jiggling and luck I finally get the cylinder to turn back and the key slides right out. Seeing if it was a one time thing, I let the car cool down and start it up and sure enough it gets stuck again. I get it out again and here I am. The key will turn to on, and turn to electric, but as soon as you turn it to start the car it gets stuck EVERY time. Please help...
Old Nov 2, 2011 | 12:19 PM
Engine: 305 TBI
Re: Key and ignition cylinder got STUCK while the car was ON and it kept trying to st
Bump...anybody.......
Old Nov 2, 2011 | 12:24 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
replace the cylinder lock.
15 dollar part from autozone (comes with new keys)
plus pick up a steering wheel puller
Old Nov 2, 2011 | 12:28 PM
Engine: 305 TBI
I ordered a new ignition assembly. But I still have a few questions, I was told there wasn't any correlation between what was happening to the starter (the grinding) and the car over heating. So why was the car over heating like ridiculously bad..
Old Nov 2, 2011 | 12:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you saying it was overheating because the gauge read high?
Old Nov 2, 2011 | 12:35 PM
Engine: 305 TBI
The gauge was over red lining and the coolant was boiling for a good couple minutes
Old Nov 2, 2011 | 01:12 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
im pretty sure when the key is in that position some of the gauges go all the way to the right. i think it is normal
Old Nov 2, 2011 | 07:24 PM
Engine: 305 TBI
If it was just the gauge than why was the coolant boiling?
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
