Gear drive
Old Nov 2, 2011 | 09:49 AM
plstu's Avatar
Gear drive
Has anyone used a gear drive instead of a timing chain on their TPI engine? I am thinking of doing this but I am wondering the effect it will have on the knock sensor since they are a little noisy.
Old Nov 2, 2011 | 10:09 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Gear drive
Some work some don't. My advice? Don't waste your time or money on it.
Old Nov 2, 2011 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Gear drive
Not worth it. Install a good quality chain and forget it. Don't cheap out on an inexpensive offshore brand. You get what you pay for. Around $100 is usually the price for a good quality timing chain set with billet gears.
Old Nov 2, 2011 | 08:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Gear drive
don't do it, it can cause the knock to retartd your timing!!!
Old Nov 2, 2011 | 08:50 PM
Twin_Turbo's Avatar
Re: Gear drive
Everyone is just repeating what the last guy said... who tested it? I had a milodon drive on an EFI motor once, never had a prob w/ the knock system
Old Nov 2, 2011 | 11:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Gear drive
I've tested it however I don't have EFI on my race engine. I had a gear drive on the engine for a day then yanked it off and reinstalled the chain. I couldn't imagine driving around with it in a daily driver.
You'll be much happier with a good chain system.
Old Nov 3, 2011 | 04:30 AM
Twin_Turbo's Avatar
Re: Gear drive
If you can hear the gear drive your exhaust isn't loud enough
Old Nov 3, 2011 | 09:24 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: Gear drive
I agree I have a Pete Jackson gear drive on my Iroc. Not one problem with it and the noise doesn't bother me cause it just about drowned out by my edelbrock 2204 cam
Old Nov 3, 2011 | 09:44 AM
Car: '87 Iroc-Z
Re: Gear drive
Exactly, I hear a slight very faint whine but I LOVE IT...The lope of my cam and exhaust is phenomenal!
Old Nov 3, 2011 | 10:22 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Gear drive
not sure how it will effect the knock sensor, but id recommend the quiet version. it gets annoying when stupid people constantly say, SOUNDS LIKE YOU NEED POWER STEERING FLUID. maybe 1 in 10 know what it is. just my experience. i guess my exhaust wasnt loud enough. lol.
Old Nov 3, 2011 | 04:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If your exhaust is so loud that you don't hear your gear drive, it'll be too loud to hear the problem that'll leave you beside the road.
Old Nov 3, 2011 | 04:59 PM
Car: '87 Iroc-Z
Re: Gear drive
Note I said I hear a faint whine, I must have the quiet one cause it's not as loud that it's annoying or attracts attention and my exhaust doesn't sound like a drag car, it's just headers and a American Thunder Flowmaster catback!
Listen to some sounds clips or text me and I'll send youa video of my car running front and back!
573-999-4623
It's not for everyone I'll admit that cause you do hear a constant whine but I love it!
Old Nov 3, 2011 | 05:28 PM
Twin_Turbo's Avatar
Re: Gear drive
Milodon gear drive: that whine is not obnoxious
http://www.youtube.com/watch?v=o_NbPKiQw1s
Old Nov 3, 2011 | 07:26 PM
plstu's Avatar
Re: Gear drive
I want a gear drive for the long term performance it gives. Buy the best chain in the world and it will still stretch although not as much as a cheap one. I ran nothing but gear drives on my older pre knock sensor engines and wouldn't run anything else. I do appreciate everyones persoanal likes and dislikes but does anyone know for sure if the knock sensor picks them up? A knock sensor is tuned and is supposed to only pick up on the frequency of KNOCKS, not the whine of a gear drive. Would love to hear success and failure stories with details as to what gear drive was used. Thanks ahead of time
Old Nov 3, 2011 | 08:17 PM
Car: '87 Iroc-Z
Re: Gear drive
Honestly thats hard to answer. Because the same reason y you want a gear drive is why it may not I'll explain. A gear drive does it job so well that in fact it transfers some of the vibration that normally would be shrugged off by a looser chain system. So depending on how well balanced your engine may or may not be it will or won't trigger the knock sensor. My L98 no it doesn't trigger the knock sensor but m engine also has been rebuilt and well balanced can't say it wouldnt work for you or would!
Last edited by KamikazeIroccy; Nov 4, 2011 at 05:22 PM. Reason: spelling correction
Old Nov 4, 2011 | 05:17 PM
plstu's Avatar
Re: Gear drive
I guess it would be a "try and see" type of thing.
Old Nov 4, 2011 | 05:23 PM
Car: '87 Iroc-Z
Re: Gear drive
You could always get a custom prom that takes the knock out of the computer
TPIS could easily do this for you
Old Nov 6, 2011 | 04:56 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Gear drive
have had a pete Jackson Q Grear drive on My Lingenfelter 383 never any probs you did not know it was even there. (no whine at all)
mech roller cam also (92 Z28 5.7 car)
but my chip was set up to tell the ecu to retard 0/0
this was back in the 90s. 92 to 2003 then the rod drop thing..
get the one with out that whine..
SIDE NOTE: iv now got a V1T Trim for the WHINE!
Old Nov 12, 2011 | 08:53 AM
plstu's Avatar
Re: Gear drive
It's gotta have a little whine.... love the sounds of a well running engine! Like listening to a live band, until one of the members die! LOL. I guess I am going to have to give in and get set up to communicate with the ECM. The guy I bought the car from had the computer built and it does a good job but I can't stand not knowing what it is and is not doing. Can someone point me to a good link on here that covers what is needed to start playing with the 'puter?
Thanks everyone.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
