My Camaro Won't Turn Over!!!
Car: 1992 Chevrolet Camaro RS 25th Anniv
Engine: V8 5.0 305 TBI
Transmission: 700R4 Auto
I have a 1992 Chevy Camaro RS 25th Anniversary Edition. It has a V8 5.0 305 TBI and a 4SPD 700R4 Automatic Transmission. I have replaced plugs, wires, cap, rotor, air filter, and bypassed the VATS. It was running before but extremely rough. At that time is when I replaced the cap and rotor. While doing so I noticed some rust and corrosion inside the cap so I cleaned it out. When cleaning it out I removed the ignition module to get out some more debri. after putting everything back to working order it will not turn over... It clicks as if the battery is dead... I've checked the coil and charged the battery... Does anyone know what maybe causing this issue? Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: My Camaro Won't Turn Over!!!
check you battery connections and battery surface voltage.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Back to basics.
Is the battery really fully charged?
What volts is it showing?
Check the connections on the heavy cables from batt to engine / starter;
are they in good cond ,clean and tight?
Hot wire the starter solenoid terminal direct to batt POS+; does starter work?
If not ;starter faulty
If starter works and you have good power at starter terminal then a problem
with starter wiring from Ign switch
Many things to work through to isolate problem
Thats all fine as well... It ran rough but ran changed out the cap and rotor got the debri and junk out took maybe 30 minutes max to reassemble and then nothing afterwards...
I know its not my battery I took my new battery out of my 98 Pontiac Firebird which is my daily driver and still won't run...
Car: 82 Z28
Transmission: T400
I will check the wiring and power to the starter tomorrow... But I seriously feel that it involves something in the distributor since it was all over a matter of 30 minutes that the car stopped running all i did was tear into the dist. cap...
Car: 82 Z28
Transmission: T400
You can take the dist out all together and engine will still crank
db057
Aug 11, 2015 10:11 PM
