need help getting to the dist bolt
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I have tryed every extension swivel head dist wrench and can not get to the dist bolt to adjust the timing the car is 89 formula tpi l98 i can get the dist wrench on then can't move it because it is on the fuel rail anyu suggestions or any one in the gurnee IL area willing to help thanks
Car: '87 Z-28
Engine: LT1-topped 400
Re: need help getting to the dist bolt
You can find a few different distributor wrenches at auto parts stores. The first time I adjusted my timing, I had to remove almost everything from the area to get at the bolt. I installed an aftermarket coil that sits about 1/2" further away from the distributor and flipped the EGR solenoid around so it sits up and away, rather than down and toward, the distributor. Now I can get a dizzy wrench in quite easily and even a regular wrench works in a pinch.
Engine: 4++,350 & 305 CIs
If the bolt has never been loosened spray penetrating lube on it 4 a few days b4 you try and work it..
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Got to a pawn shop in their assorted tool bins find the wrench you need preferably closed end with a long handle lay it across a stove burner let the flame turn it red hot then slowly shape it fit the space you have to get to the bolt.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks its not that it is stuck just move the wrench once it is on no room i will give it another shot thanks
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
That's right. I had to use an open end wrench and bend it into an L shape. Not quite a 90 degree angle though , a little less.
Axle/Gears: 3:42
Also had to remove my coil and egr solenoid to gain access to the bolt.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i bought a dizzy wrench from summit. yes its tight and you can barley move the wrench to loosen the bolt but it does work
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I was able to get a universal joint long extention and guilded it in and worked fine.But that was on a v6.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
