Would a HV/HP oil pump pull too much oil through a 7 QT pan?
Old Nov 19, 2011 | 06:25 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I have noticed through an electric OPG (auto meter Ultra lite) That at higher RPM's that the pressure will drop to almost 0 and it looks like sometimes 0. Bad OPSU? Using brand new gauge and brand new auto meter OPSU. When warmed up, car idles with around 25 PSI. Thing is, I don't remember if I used a standard oil pump or a HV/HP!
Old Nov 19, 2011 | 06:51 PM
grumpyvette's Avatar
Re: Would a HV/HP oil pump pull too much oil through a 7 QT pan?
no! but having the oil pump pick-up fall off the pump, or having the oil pump pick-up being mounted too close to the oil pan floor WOULD produce those symptoms
http://forum.grumpysperformance.com/....php?f=54&t=52
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
