1983 trans am
Old Nov 23, 2011 | 02:51 AM
gman1989's Avatar
Car: 1983 trans am
Transmission: 700-r4 B&M console megashifter
1983 trans am
hey everyone i have an 83 pontiac trans am that im trying to get road worthy but i hit a bit of a snag when i turn the car on and I try to put it in gear it shuts off. and the only way i can move the car is when i step on the brake put it in gear and rev the engine but that just makes the car burnout and when i let go of the gas pedal the engine just shuts off i dont know if its the carburetor or something else can somebody help me
Old Nov 25, 2011 | 08:41 AM
Vader's Avatar
Re: 1983 trans am
Does this happen with a cold engine? Only when hot? Always?
Some things to check would be choke actuation and pull-off (for a cold engine), fuel bowl level, idle mixture base setting and MCS setting, curb idle speed, and vacuum leaks of any sort.
Old Nov 26, 2011 | 08:43 PM
gman1989's Avatar
Car: 1983 trans am
Re: 1983 trans am
it always happens
Old Dec 20, 2011 | 02:33 PM
gman1989's Avatar
Car: 1983 trans am
Re: 1983 trans am
it will idle once i get the rpm high for a few minutes then it idles fine then when i put it in gear the car shuts off
Hawk312
Aug 22, 2017 08:55 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
3tas4me
Sep 4, 2015 01:45 PM
Thaney9
Aug 29, 2015 03:16 PM
Dan's 83z28
Exterior Parts Wanted
Aug 20, 2015 02:16 AM
