could a 85 Corvette starter work on a 92 Camaro
Old Nov 27, 2011 | 10:41 AM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Needing to know if you have personal experience with this. I checked bat Oriellys yesterday and they have different part numbers, however I've heard that if they have the same flywheel they might work, which the both have the same flexplate tfor the 700r4. Thank you
Old Nov 27, 2011 | 10:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: could a 85 Corvette starter work on a 92 Camaro
they look to be the same. If you goto rockauto.com and do the lookup on both engines for example it shows acdelco p/n 3361880 for both applications. later years l98 on the vettes use a a light weight starter.
https://www.thirdgen.org/forums/tech...gh-torque.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
milk
Aug 10, 2015 06:26 PM
