stock starter OR high torque starter???
Hey guys im trying to fire up my 89 Iroc. I threw out the stock 305 tpi and dropped in a carburated 383. At first it wouldn't turn and it sounded weak. Turns out that the battery was bad. I bought a new battery and tried again, it was more aggressive this time but it still wouldn't turn.
Maybe my stock starter has gone bad? Would a new stock starter do? Or must I get a high torque starter? The car is manual if that matters.
Thanks guys!
Thanks guys!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: stock starter OR high torque starter???
If buying a new starter anyway, might as well get a mini high torque starter. Got mine off ebay for $80 shipped - been great for over a year now!
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
IMO all stock starters from the 16th century should be rounded up and thrown into a large volcano. A mini starter will be way lighter, more powerful, FAR FAR less bulky, and won't try to pull your hands to the centre of the Earth when you drop them out.
I wrestled mine off and back on for several years until it finally died, then replaced with a mini. Realised immediately that I should have tossed it the first time I pulled it, just on principle's sake.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
1/2 the size and weigh of stock Delco one
Fits any 153 tooth ( straight bolt pattern ) flywheel
http://cgi.ebay.com/ebaymotors/Corve...item588f06bedb
Engine: 4++,350 & 305 CIs
Thats the starter Ive been using since they came out. They are great..
Car: 89 Formula
Engine: 383 SBC/HSR
Or you can use and LT1 starter.....they're smaller and have more kick. I've been using one for 5 yrs and it seems to work great on 3rd gens.
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
I had to use a high torque starter on my 383. The stock starter just didn't have enough power to turn the motor over very fast.
If your compression is over 10:1 I would get a high torque one.
I got this one http://www.summitracing.com/parts/SUM-820323/ which is good for up to 18:1 compression.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
That does sound like a starter. You can take it off the car and take it into an autoparts store such as Advanced or AutoZone most of them can bench test the starter for you on the spot.
If you have headers or want to put them on down the road a mini starter will give you more space which means the starter won't fit as tight against the exhaust.
Also most mini-starters offer high output and clockable position so you can adjust them for the headers.
I've used 2 of the hitachi type generic mini starters. Both worked good. The first one shorted out after 8+ years of service so the 2nd one is on there now. It cranks over my 10.1:1 CR solid roller setup just fine. I also have another brand in the garage but the solenoid design is different and its kinda in a weird spot on it so it would reclocked to fit correctly with my current long tubes.
Thanks guys. I found these two that I like. Could you guys confirm if either would work for my Iroc? And which would you pick?
http://cgi.ebay.com/ebaymotors/SBC-B...item2c5ea61343
http://cgi.ebay.com/ebaymotors/SBC-B...item45fc33d75e
Engine: 383 SBC
2nd one looks like the one I use. It's decent.
Car: 82 Z28
Transmission: T400
Those both look like the cheeeeeeeeeeeeep made in China knockoffs of a Hitachi... use at your own risk... no idea whether parts that fit the actual Hitachi piece will work in that "product" or not, for example; might be a total throw-away when it breaks
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Denso mini as used on Corvette late L98 and LT1 engines
Oh yeah, I am at 10.3 to 1 compression and it turns it over with no problem.
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
You know those mini torque starters are clock-able. You can rotate it 360deg to get it away from most configurations. With my hooker long tubes I had to machine the solid aluminum mounting block though. Nothing an angle grinder, or a file and a lot of Patience could not take care of.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 82 Z28
Transmission: T400
Original Denso unit from my 89 Vette is turning over my 12:1 383 no probs.
With a good tune ,on a cold start it doesn't even crank over; just fires up as soon as you turn the key
I see. So the two I posted earlier aren't the best. Suppose I did Summit. Which would you recommend? I think one of you already posted a link, but I'll just ask again. Thanks guys!
Car: 89 Formula
Engine: 383 SBC/HSR
Just use the LT1 starter, already!!!
Go to your local parts get it there, comes with a warranty, and you're set. I've burned up a couple of them, and it's nice to just walk in with my core and get another one. You won't regret it.
Car: 89 Formula
Engine: 383 SBC/HSR
Yes, I got mine from Autozone, it's the one off of the 93-97 Camaro/Firebird. Make sure you get the shims with it, you might need them if it wants to bind after cranking.
No prob, glad to help.
Car: 82 Z28
Transmission: T400
I just went to Autozone. They have a lifetime warranty, remanufactured starter for a 93 V8 Camaro for $170. My question is, even though this is a stock starter, is it considered high torque? Does it have enough juice to start my new 383? If so, I'll go back right now and get it. I just want to make sure before I spend this kind of cash.
Car: 89 Formula
Engine: 383 SBC/HSR
Check out my signature, it starts my engine without a problem. If your compression is under 13:1 then you'll be fine.
This is the engine I purchased from Summit. Think your recommended starter will do?
http://www.summitracing.com/parts/MLL-BP3832CT1/
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, it'll do. The fact that it's rated at 330hp means its probably 9.5:1 compression....or close. A stock LT1 has a 10.5:1 compression ratio.
db057
Aug 11, 2015 10:11 PM
