Steering column question -- works fine, but tilt steering has play in it
Old Nov 20, 2011 | 02:42 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
This may be a silly question. 84 T/A, tilt steering. The tilt works just fine, but once it's locked into place, I can still move the steering column "up" with about an inch of play. Is there a reason for this? it should be locked in with no movement right? It won't go "down" but I can move it up.
Is it possible to disassemble the column and tighten down a bolt or something?
Old Nov 20, 2011 | 04:19 PM
ex-x-fire's Avatar
Re: Steering column question -- works fine, but tilt steering has play in it
Its usually 3 screws that loosen up, I think they are behind the turn signal switch. Sometimes they strip out, you can use epoxy to keep them in.
Old Nov 24, 2011 | 02:17 AM
Ozz1967's Avatar
Car: 1984 Trans Am
What is the best way to get to those screws? Pull the steering wheel?
Old Nov 24, 2011 | 06:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following sticky may be helpful:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Nov 24, 2011 | 09:24 AM
Ozz1967's Avatar
Car: 1984 Trans Am
JamesC
That will help alot! Thanks!
I don't have a steering wheel puller though...or access to one. Will I still be able to remove the wheel with some elbow grease or am I stuck without it?
Old Nov 24, 2011 | 06:34 PM
flippowill's Avatar
Car: 82 Camaro (4cyl body)
Engine: 454 bbc
Transmission: th400
Axle/Gears: 7.5"
Gotta have apuller or the wheel will prob get bent and or destroyed! You could rent one fron Autozone?
Old Nov 24, 2011 | 06:36 PM
Ozz1967's Avatar
Car: 1984 Trans Am
First post! Welcome to TGO!
You didn't check my location. I'm in the UK mate! LOL It's cool though. People here aren't cool like AZ or O'reillies. No one "rents" tools out that I've found...at least not near me. To order one puts me back another week on this and from what I"ve read, I don't know if it'll last that long.
Old Nov 24, 2011 | 06:50 PM
flippowill's Avatar
Engine: 454 bbc
Transmission: th400
Axle/Gears: 7.5"
oops! good luck! just take your time pulling that thing off!
Old Nov 25, 2011 | 06:03 AM
ex-x-fire's Avatar
A gear puller will pull the steering wheel, you'll need that tool to compress the locking wheel, so you can get the snap ring off.
Old Nov 27, 2011 | 12:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yeah, I got it. Neighbor had one. Took me nearly 8 hours because I was going slow and didn't want to put things in wrong. Then broke the small plastic horn button, the round piece that goes under the lock ring. It's so stupid, not even sure how it broke. Then the high beams lights didn't work, took me nearly an hour to figure out that the lever came off the switch down under the dash. I was looking for an electrical connector or something in the column. Other than that, it was fairly strait forward. I did not get the top two tightened down, but the bottom two snugged the whole thing up gut N tight.
Old Nov 27, 2011 | 12:09 PM
JamesC's Avatar
Did the same a while back messing with a new steering wheel. I replaced the cam this summer with a bone yard piece.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Bull86
Aug 10, 2015 05:43 PM
Fronzizzle
Aug 9, 2015 01:15 PM
