broken odometer
Old Nov 29, 2011 | 10:24 AM
91RealSlow's Avatar
Car: 1991 camaro RS
Axle/Gears: Stock 273?
broken odometer
Ever since I bought my camaro the odomeder has been broken...its a 91 camaro rs 305 tbi
Has this ever happend to anyone?any way I can fix it?
Old Nov 29, 2011 | 10:27 AM
jahblah's Avatar
Car: 87' Firebird Formula
Re: broken odometer
mine just recently stopped rolling!!! like 2 days ago!!! i was like WTF!!! speedo still works though. but idk how to fix...maybe get another one. just wanted to share pain with ya.
Old Nov 29, 2011 | 02:22 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: broken odometer
Does the speedo work? If not, it's probably the cable.
https://www.thirdgen.org/forums/elec...eter-trip.html
Old Nov 29, 2011 | 03:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: broken odometer
A '91 would not be cable driven.
JamesC
Old Nov 29, 2011 | 03:44 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Re: broken odometer
JamesC
Correct!
I totally missed the year lol
Old Nov 29, 2011 | 07:30 PM
91RealSlow's Avatar
Car: 1991 camaro RS
Re: broken odometer
Yeah it's a little odd the spedometer works perfect it's just the odometer that's messed up... I don't mind it too much but I'd like to get it fixed eventually
Old Dec 3, 2011 | 07:18 AM
geoff jaymes's Avatar
Car: 1987 Pontiac Trans Am
Engine: LB9 305 TPI
Axle/Gears: Limited Slip, possibly 2.73
Re: broken odometer
I'm about to change my speed sensor out on my 87 TA with 305 and 700r4, only because it worked fine before i swapped trannys out, replaced tranny with another 700r4 from same car, and no odometer and speedo, all other gauges work fine. so I took the speed sensor off my old tranny and have attempted to change them out, but it seems i'm going to have to pull my tailshaft housing to be able to get the broken speed sensor off. kinda sucks trying to do all this in my drivway with a jack stands, i called a few shops, sounds like i could get it done for about 50 bucks. i just hope this will fix my problem when it's all said and done.
Old Jan 10, 2012 | 02:37 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: broken odometer
autoinstruments.com can repair your speedo
Old Oct 25, 2013 | 08:52 AM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
Axle/Gears: 2.73 posi rear
Re: broken odometer
I have a 1992 firebird. The speedo works just fine, but the odometer and trip odometer only intermittently work and the trip odometer will quickly move to 0 when passing 9 in the 1/10ths dial.
Did anyone figure out what the deal is? I'd rather a quick fix than sending it out for $200+ and 4 weeks.
Old Apr 30, 2017 | 11:45 PM
OldMuscleCarGuy's Avatar
Car: 1992 Camaro RS
Engine: 3.1 Liter V6 TPI
Transmission: Automatic
Re: broken odometer
Just for grins and giggles, check the connections to the speedo circuit board. I have a '92 RS and the speedo works but the trip and OD don't. After I pulled the board I found very tarnished solder strips. Cleaned them up with 400 wet/dry sandpaper. I also found the one electrolytic capacitor, 150uf @25VDC was leaking. I'm mainly an electronics guy & ham radio operator, so these kinds of failures are a serious red flag. The liquid inside one of those caps can eat through foil paths and did on mine. I replaced the cap and ran a jumper wire to replace the bad foil path. Tomorrow I'll put a few drops of oil on some of the gears before reassembly. I also found that the copper foil paths on the plastic circuit board that connects the cluster to the connectors in the dash were tarnished also. Some of the tabs had came loose form the circuit film too. I super glued them back to the plastic film and cleaned them with 400 grit also. I'll post back when I put her back together and let everyone know if this procedure worked.
I'm new here and would like to thank everyone on these forums for sharing, I've learned a lot from reading your posts.
Ham call sign is : N8TCQ ...... look me up on QRZ.com
Thanks for reading this.....
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
