little help with intake
Old Dec 2, 2011 | 08:29 PM
SaltLifeCamaro's Avatar
Car: 86' Iroc-Z
Engine: tpi 350 small block
Transmission: a4 :)
Axle/Gears: bone stock for now
anyone up for giving me an order in which i should start to take of my intake manifold for my 87 small block 350 tpi.
Old Dec 3, 2011 | 10:51 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: little help with intake
Disconnect the battery (for safety), then fuel lines and throttle and transmission cable (if it's an auto). The plenum needs to be removed from the runners, then the runners from the intake, then pull the distributor. This gets you down to the intake itself. There are various vacuum lines and the coolant tube to the throttle body, but those are easy and the sensor connectors are too. You don't have to worry about mixing them up as they only fit the particular part they are designed for. The fuel rails will be after the runners, but they are easy, I think 4 bolts holds them in. The injectors simply unplug from the harness. I may have missed a detail or two, but this should get you on the right track.
Old Dec 4, 2011 | 06:58 PM
Car: 86' Iroc-Z
Transmission: a4 :)
little update on progress discovored that if u give a couple taps to the front passanger side of the plenum and it help loosen it. im a little weary of the fuel lines and fuel rails any tips would be great help. otherwise so far so good.
Attached Thumbnails little help with intake-032.jpg   little help with intake-037.jpg   little help with intake-039.jpg
Old Dec 4, 2011 | 07:27 PM
jtsk's Avatar
Just disconnect the two fuel lines at the front and then the 4 bolts that hold the fuel rail down. The injectors just press into the intake and will come out with the rails. You will have to apply some leverage because after so long, they will be stuck a bit.
Old Dec 4, 2011 | 07:29 PM
jtsk's Avatar
By the way, the bracket on the front that the fuel lines go through is bolted to the front of the motor if my memory serves me correctly.
Old Dec 4, 2011 | 07:39 PM
Car: 86' Iroc-Z
Transmission: a4 :)
YES IT IS WILL I NEED TO PLUG THE FUEL LINES AFTER DISCONECTING THEM?
Old Dec 4, 2011 | 07:42 PM
jtsk's Avatar
yes, you need to in order to keep debris and dirt out. I capped mine with some aluminum foil and zip ties and then covered them with a ziplock bag. Had to do it the cheap way because I didn't have any plugs or caps, but it worked fine.
Old Dec 4, 2011 | 08:52 PM
Car: 86' Iroc-Z
Transmission: a4 :)
cool thanks going out to do this now
Old Dec 7, 2011 | 10:39 PM
Car: 86' Iroc-Z
Transmission: a4 :)
another update all thats really left is the distributor i think. Going pretty smooth right now. really just been cleaning everything.
Attached Thumbnails little help with intake-007.jpg   little help with intake-013.jpg   little help with intake-014.jpg
Old Dec 7, 2011 | 10:43 PM
Car: 86' Iroc-Z
Transmission: a4 :)
not quite finished but coming along nicely
Attached Thumbnails little help with intake-015.jpg   little help with intake-016.jpg   little help with intake-017.jpg
Old Dec 8, 2011 | 05:15 PM
jtsk's Avatar
Looking good! I did the same thing, cleaned up everything and then I put some Duplicolor engine paint (aluminum) on them. It all looked great! Would send a picture, but my computer crashed and all my pics were lost.
Old Dec 8, 2011 | 05:55 PM
Car: 86' Iroc-Z
Transmission: a4 :)
thanks yeah good idea i never thought about the paint
Old Dec 12, 2011 | 06:49 PM
Car: 86' Iroc-Z
Transmission: a4 :)
well i went with the paint i am still waiting on the intake but got gaskets today so i did the valve covers. i painted everything else as well. hope the intake gets here soon this car is my everyday driver so i need it on the road quick!lol
Attached Thumbnails little help with intake-002.jpg   little help with intake-005.jpg   little help with intake-006.jpg
Old Dec 12, 2011 | 06:53 PM
Car: 86' Iroc-Z
Transmission: a4 :)
few more. last one is just for fun
Attached Thumbnails little help with intake-004.jpg   little help with intake-013.jpg   little help with intake-014.jpg
Old Dec 12, 2011 | 07:19 PM
jtsk's Avatar
Looks brand new! Will be sharp when you get it done.
Old Dec 12, 2011 | 07:22 PM
Car: 86' Iroc-Z
Transmission: a4 :)
the insides do to. what a pain in the ***. but yeah thanks i cant wait to see it bolted together.
Old Dec 12, 2011 | 07:42 PM
jtsk's Avatar
You said you hope the intake gets here soon, are you installing a different intake or what?
Old Dec 20, 2011 | 08:40 PM
jtsk's Avatar
Any further progress?
Old Dec 23, 2011 | 12:09 AM
Car: 86' Iroc-Z
Transmission: a4 :)
Yeah well it's stock but new to me. Intake got here yesterday so at this point no new progress yet. Really sucks having to find a ride to work everyday. Lol. If I am this far with the motor in, do you think I am capable of changing my head gaskets? I did valve covers already.
Old Dec 23, 2011 | 07:19 AM
jtsk's Avatar
Yes, you could change them, but unless you have a problem with one there is no need to. You'll have to go through the pain of removing the exhaust manifolds to do it. I recommend not doing it though unless you really need to.
Old Dec 23, 2011 | 09:21 AM
Car: 86' Iroc-Z
Transmission: a4 :)
Fiat enough. Really doesn look to easy but I know the car had issues with over heating a little before I'm thinkin it couldn't hurt at all to change them. but ur right looks like a real pain in the ***
Old Dec 23, 2011 | 09:33 AM
jtsk's Avatar
The overheating is common on these cars, but most likely unless it SEVERELY overheated, your head gaskets are fine. If you don't have water in your oil, or oil in your water or blowing white puffy (steamy) smoke when you are driving you are fine. If you pull your dipstick and it looks kinda milky that's oil and water mixed. New thermostats, fan switches, and temp sensors maybe in order though, and since you have the top end off, easy to replace as well, so I would go ahead and do those.
Last edited by jtsk; Jan 1, 2012 at 01:34 PM. Reason: added "don't" to make the sentence make sense.
Old Jan 6, 2012 | 08:36 PM
jtsk's Avatar
How's the project coming along?
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
