1991 Z28 No reverse lights
Old Dec 9, 2011 | 06:17 PM
Skoutariotis's Avatar
Car: 1991 Z28
Transmission: Manual
Bulbs ok, sockets don't have current, tail lights work, turn and hazard work.
Is there a switch on the outside of the gear box I can check on? Need some direction. Thanks!
Old Dec 9, 2011 | 07:05 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 1991 Z28 No reverse lights
Is it a manual trans? If so, the switch is on the trans. If it's an auto, the switch is on the shifter. The wire to the lights from the switch is light green. The power into the switch for the B/U lights is dark blue. Check the DIR B/U fuse in the underdash fuse panel.
Edit: Just reread your post. You have turn signals so it wouldn't be the fuse. Almost has to be the switch or wiring. Generally the switch fails.
Old Dec 9, 2011 | 07:20 PM
Car: 1991 Z28
Yeah, the fuse is ok, sorry forgot to mention it. I'll check the switch, hopefully I'll be able to find it. It is a manual, and the darn thing is so close to the ground, I'll have to put it on jacks. Thanks for the info.
Old Dec 10, 2011 | 07:34 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
switch is on the driver side, located about halfway down the trans.
Old Feb 2, 2012 | 04:50 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Is there any kind of adjustment or is it simply wiring and a switch? I'm having an issue with my reverse lights as well. Seems I have to move the stick around to get the lights to come on. I have the manual transmission.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
