2-piece RMS replacement
Old Dec 20, 2011 | 12:22 AM
rmulle1986's Avatar
Car: 1992 Camaro Z28 G92
Engine: Pre-86 350 4 bolt. Carbed
Transmission: Borg-warner 5 speed
Axle/Gears: 2.73 non posi for now
question, I have the same years block on my 92 Z28. The rear main is leaking bad, and needs to be replaced. Motor fine..long story why the seal is garbage now.
I know that it is a 2 piece rear main because mine is a 4 bolt as well..yes i kept it carbed, i like that better. My question is this. Can I keep the motor in the car without pulling it up or out a little to replace it? Also, whats the average cost of a rear main 2 pice for a 350 4 bolt block? thanks
Old Dec 20, 2011 | 12:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 2-piece RMS replacement
I moved this from the thread you posted in because it had nothing to do with the thread you posted in (that's a TGO rule, you know) except the year of the engine.
2-piece rear main seals are cheap. A few bucks. The expense comes in the labor.
Yes, it can be done with the engine in the car. A bit tricky, but do-able. With 1-piece RMS, you either have to pull the engine or drop the transmission.
1- or 2-piece RMS has absolutely nothing to do with whether it is 2- or 4-bolt main. Both came with both. However, if your engine is 1974, it will be 2-piece RMS. It could still be either 2- or 4-bolt main.
Old Dec 20, 2011 | 10:04 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Just pull the motor you can pull it and put it back in in a night.
Old Dec 21, 2011 | 01:30 PM
five7kid's Avatar
I have to have a pretty good reason to pull an engine. Replacing a rear main seal doesn't qualify.
Old Dec 21, 2011 | 05:23 PM
We each have different tools, setups, and tolerance for laying in puddles of petrochemicals; but me personally, I'd pull the motor. Not only do I spend less time laying on my back with funk dripping on my face, but also, the odds of getting it back together PERFECT and LEAK-FREE are vastly better.
Just MHO.
Out-Cast
Dec 31, 2015 04:40 PM
MoJoe
Sep 24, 2015 09:12 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
