EGR valve vacuum question
Old Jan 1, 2012 | 02:22 PM
buckweber's Avatar
Car: 1989 RS Convertible
Engine: 305 TBI
Transmission: Automatic
I took pictures of my vacuum lines before removing but lost pictures. A vacuum lines from the egr valve to the control module. A separate line runs from the control module to a vacuum port on the front of TBI. How do I tell what port on the module goes to what. Any help would be appreciated. Car will not start after taking the top end apart. Car will start once for about 2 seconds and then will not start. I checked timing and it seems to be correct. Would having the lines to the egr backwards cause this problem?
Old Jan 1, 2012 | 03:46 PM
ex-x-fire's Avatar
Re: EGR valve vacuum question
Egr doesn't or shouldn't operate at idle or on a cold engine. Is the emissions sticker still there? It has a vacuum diagram.
You can't check timing w/ out the engine running, turn the distributor alittle more to see if it'll start up.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
