another oil sender wiring question
Old Jan 4, 2012 | 09:48 PM
dcil's Avatar
I did the search but didn't find what I'm looking for.
My 82 was a 305 crossfire car. The P.O. put in a 350 out of a 75 truck. The oil sender and the temp sender are not hooked, no temp sender (no prob on thet one). The oil sender in the motor is a single wire bell type. The only wire I can find in that area is a 3 wire plug. According to what I found on search, the original could have beeen a 3 wire. Here's my 2 part question.
With the sender unhooked the gauge is pegged passed 60. Shouldn't it read 0? Or is my gauge fubard.
Which of the 3 wires do I use on the sender? Supposedly the other two are for the fuel pump safety disable. I know the sender is probably not the right one, but it's easy enough to get one.
Old Jan 5, 2012 | 12:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: another oil sender wiring question
Originally Posted by dcil
a 3 wire plug.
Org and red wires are for the pump switch
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Jan 5, 2012 | 06:50 PM
dcil's Avatar
Thanks, you guys rock
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
penguinpanda0
Aug 15, 2015 06:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
