"055" intake manifold
Car: '90 IROC-Z 1le
Can anyone tell me if an early '80's casting #055 intake manifold (Q-jet) is alum or cast iron. I believe this came on the '82-'84 150 HP motors.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: "055" intake manifold
I assume you are not in a position to lift the intake as that is a dead giveaway.
In any case if you have the FULL casting # of the intake you should be able to Google it
Car: '90 IROC-Z 1le
ZimGTA, I may be dumb, but I'm not that stupid. If I had the manifold, I think I could tell the difference. But, I don't have it yet. That's the manifold I'm required to run with a NHRA stock eliminator car and I was wondering if it was iron or aluminum.
Full # is 14057055.
Full # is 14057055.
Many of those early 80s intakes were aluminum. The auto industry was into weight savings to help increase fuel economy back then and it marked the beginning of many company's diving into lighter weight materials in mass-produced vehicles.
If it's aluminum there will often be a series of lines cast into the runners on the outside where you can see them. At least I've noticed that seems to be a common differentiating characteristic between the aluminum and cast iron version of what are basically the same intakes.
But since you're class racing it's pretty unlikely they would spec an aluminum intake- stock or not.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
