how to tell a true 350
ok guys. i know that the only way to tell if your motor is a 350 and not a 305 is to check the casting. but on our camaros it's very hard to get back there and see. so does anyone have any tricks that i can use to help me see it besides pulling the whole dang motor?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: Turbo Z31, RX7, and 2 F-bodies
Engine: 1.LS1, 2. L98
Transmission: 1.4L60E, 2. 700r4
Axle/Gears: 1. 3.23, 2. Unknown
Re: how to tell a true 350
Castings.
Don't let people tell you otherwise when saying the alternator is on the left/right/etc.
Also, you can check your vin. How true that will be is anyone's guess, but depending on the year, you would check the 8th digit for an F or an 8 (I know this is true of Firebirds and T/A's).
Car: 82 Z28
Transmission: T400
Unless something happened to the original engine, I don't see why it would be pulled out. I can understand if the original (be it a 350 or w.e.) blew and the previous owner threw in another F-body V8 (a 305 or possibly a 350) which again is very possible, not arguing against it.
Car: 82 Z28
Transmission: T400
So VIN basically irrelevant?
You see it happening on here all the time.
Guys pulling engines for all sorts of reasons ( not only because engine is kaput )
For instance; they have several cars and one body is better than another
or they found something at the junkyard or their buddies place for a good price
or having to keep a DD running ,they are putting in a newer / older /bigger /smaller or even truck engine
depending on their circumstances and budget
Transmission: 4L80E/4L80E
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
If you have the chance, pull your valve covers too and get each head casting number. That way you will know for sure which heads you have too.
Car: 1984 Camaro Z28
Engine: 4 bolt 350
Axle/Gears: Richmond 3.73 spool 10 bolt
Still not a for sure way to find out tho. When I bought my Camaro and tore into the engine, it had a 4 bolt 350 block from an 85 truck (via casting numbers) and had the origional 305 H.O. heads (vin g 1984 z28) The only sure fire way is to look up casting numbers. Had I looked at the vin and pulled the valve cover, I would have thought for sure I had the origional 305 H.O. in my car.
Axle/Gears: 3:42
Engine: 4 bolt 350
Yeah realized that after I posted it, didn't feel like editing it lol. Sorry
Billy Decker
Sep 4, 2015 03:46 PM
