Power steering bracket help
Old Jan 19, 2012 | 05:14 PM
Camaropower169's Avatar
Car: 1984 Camaro Z28
Engine: 4 bolt 350
Axle/Gears: Richmond 3.73 spool 10 bolt
Trying to put my accesories back together, and I have no clue how to put my power steering pump brackets back together (fail) I have searched, but the pictures weren't available anymore. If someone has a project apart right now, it would be awesome to post a picture of how the brackets are set up. (A/C has been removed) Thanks in advance
Old Jan 19, 2012 | 06:36 PM
ex-x-fire's Avatar
Re: Power steering bracket help
Heres some picture, I hope they help ya.
Attached Thumbnails Power steering bracket help-p5220145.jpg   Power steering bracket help-p5230151.jpg
Old Jan 19, 2012 | 09:29 PM
Engine: 4 bolt 350
That's essentially the same setup as mine even tho mine is v-belt correct?
Old Jan 20, 2012 | 05:54 AM
ex-x-fire's Avatar
That p/s pump in the picture is a v belt.
Old Jan 20, 2012 | 06:12 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well a/c and non a/c have different bracket setups for the p/s
so...
you gotta make sure you have all the correct pieces for one or the other only
or no worky
and also if it doesnt have stock exh manifolds it will mess up things as well since lower front bracket bolts to front exh manifold bolt on the older sbc engines for example and there were a couple different ones of this bracket as well, some were stud attached to this bracket type and other had welded on nut on it for a bolt to hold pump bracket to it with said bolt
and then starting in '85 there was the combo of small/narrow early serpentine and v belt both on same engine
but the p/s stayed v-belt on this, until 87
so 85 and 86 were oddball half and half
so that makes it fun too
your best bet is to snag whole setup off a complete engine
for with or without a/c
and for correct year style that yours is
or youre probably gonna be scratching head alot and for a long time here
Old Jan 21, 2012 | 02:19 AM
Engine: 4 bolt 350
Thanks for all the info guys. My mind must've played a trick on me because I could've swore I seen a serpentine belt in one of those pictures, but clearly I didn't lol. My 84 had A/c but it no longer does now, So maybe I can find a setup from a junkyard that was non ac. I will be running long tubes as well, but I was thinking about just trying to use a stud for one of the bolts just like it was before
Old Jan 21, 2012 | 07:29 AM
ex-x-fire's Avatar
Why don't you show us a picture of your brackets?
Old May 11, 2020 | 04:46 PM
Tidan's Avatar
This helped me too!
Is the smaller bottom bracket neccessary? I'm installing headers and have deleted my AC and want to simplify the bracket arrangement so its easier to work on and cleaner.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
