Didn't pass smog, high hc and no
Old Feb 2, 2012 | 09:38 AM
anomolee's Avatar
Hi Guys,
I tried to smog my car the other day and it didn't pass. I've listed my info below. Any ideas where to look on this?
87 Iroc 305 TPI
3 years ago new cat and egr valve
at 15 HC max-83, meas-82
at 25 HC max-61 , meas-63
at 15 NO max-541, meas-330
at 25 NO max-498, meas-870
Old Feb 2, 2012 | 09:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Didn't pass smog, high hc and no
What are all the gasses?
Old Feb 2, 2012 | 09:55 AM
anomolee's Avatar
CO2 - 15mph meas-13.5 , 25mph meas 13.4
O2 - 15mph meas -1.4 , 25mph meas 1.9
Old Feb 2, 2012 | 10:07 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What about CO?
Old Feb 2, 2012 | 10:09 AM
dlambunion's Avatar
Car: 1990 firebird formula 5.0
Engine: 305 tbi
Axle/Gears: 2:73
Originally Posted by anomolee
87 Iroc 305 TPI
My thoughts would be that during the three yrs since EGR replacement it has built up more carbon... Which can cause higher comb. temps which result in the higher nox. I would seafoam it if you havent. It lowered my nox n co when I failed. Plus added a new muffler since I had a stock one. It made a change.
Old Feb 2, 2012 | 10:11 AM
anomolee's Avatar
Sorry,
CO - 15mph max .5 , meas .18
25mph max .41 meas 0.0
Old Feb 2, 2012 | 01:28 PM
anomolee's Avatar
Did I lose you guys?
Old Feb 3, 2012 | 08:39 AM
anomolee's Avatar
Any ideas?
Old Feb 3, 2012 | 02:29 PM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
Do the spark plugs,wires,distributor new or worn?Do oil change and retard the timing some
Old Feb 3, 2012 | 02:34 PM
anomolee's Avatar
Do you think the oil would make a difference?
Thanks again
Old Feb 3, 2012 | 02:36 PM
m16a2r's Avatar
Transmission: 700r?
Yeah i would say so,engine has to work harder when oil is contaminated
Old Feb 3, 2012 | 02:39 PM
anomolee's Avatar
Thanks. I've always used 20 / 50 oil on my high mile car. Recently my mechanic told me to use 10/30. What do you guys think? Over 200k mi.
Old Feb 3, 2012 | 02:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is it burning oil?
Old Feb 3, 2012 | 03:47 PM
anomolee's Avatar
It does go through some oil. Not super fast but I do have to add. Would the 20/50 make the engine work harder than the 10/30? That's what I was told. Which would be better for my situation with the high nox ?
Old Feb 3, 2012 | 04:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oil viscosity isn't going to make much difference to anything.
Burning oil could cause high HC, and high NOx could be a timing or EGR problem.
Old Feb 3, 2012 | 05:26 PM
m16a2r's Avatar
Transmission: 700r?
Check your o2 sensor too,might be time to replace and warm your car up good befote test
onefreakz
May 14, 2018 12:15 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
g.l.mos
Aug 22, 2015 12:02 AM
