how do you pinpoint a vacuum leak?
Old Feb 5, 2012 | 10:51 PM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
my 92 Camaro RS is idling OK but it's still acting like it has a slight vacuum leak. i just replaced my EGR valve and thinking about replacing the solenoid for the hell of it. Does anyone have any tricks for pinpointing a leak?
Old Feb 6, 2012 | 12:34 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: how do you pinpoint a vacuum leak?
Use a portable propane bottle. Take the nozzle off and attach a rubber hose over the end of the tube. Turn the bottle on just enough so that there's some propane coming out and keep the bottle upright. Now with the engine running (outside and out of the wind), move the rubber hose around areas you think might have a vacuum leak. If there is a leak, it will suck in the propane vapors and the engine rpm will increase slightly.
Trying to find a vacuum leak by spraying WD-40 around the engine has never worked for me. It's usually hit or miss.
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
86IROC112
Nov 27, 2015 09:54 AM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
