is it bad to hit the red line?
Old Feb 13, 2012 | 12:04 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
like..i know its generally bad to bounce it off the red line but like..every now and then, is it going to hurt the motor?
Old Feb 13, 2012 | 01:08 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: is it bad to hit the red line?
On an engine in a good state of repair, probably not.
Old Feb 13, 2012 | 02:05 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
huh? lol
Old Feb 13, 2012 | 07:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The red line on the tach should be your highest shift point. It's where the engine stops making power. Changing a camshaft and other components means the red line changes. The maximum rpm the engine can go to depends on the condition of the engine components. Worn out valve springs can really limit the engine's highest rpm.
Taking an engine too high can cause damage but it depends on the conditions.
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28_AJ
Aug 27, 2015 08:59 PM
Golfvette
Aug 24, 2015 06:35 PM
Linson
Aug 21, 2015 02:12 PM
