Cant find a head gasket
Old Feb 13, 2012 | 06:06 PM
Nicelysedated's Avatar
Car: 1991 Z-28
Been looking for hours but can't find a head gasket that will work. I wanted to find a gasket that would get my quench around .040. My pistons are around .017 in the hole and I have a bore size of 4.145. Anyone know of a gasket around .023 compressed thickness?
Old Feb 13, 2012 | 07:16 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: Cant find a head gasket
I can only find ones in .039 for that bore size and only available in copper. Why is the deck height so weird? Normally its done to the nearest .005". Why can't you have a little larger quench? Is this a high tolerance race motor?
Old Feb 13, 2012 | 07:31 PM
Car: 1991 Z-28
I wanted to get to as close to optimal as possible. The block is at the stock 9.025 height an the pistons have a 1.425 compression distance. That should put them .025 in the hole. I haven't gotten the motor yet, so I am going off what the current owner measured. He measured .017 in the hole. A head gasket with a thickness of .039 and a piston depth of .025 is gonna put my compression lower then I wanted. I thought 0.020 head gaskets would be common. I was wrong.
Old Feb 13, 2012 | 07:34 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Look up Cometic. I believe they'll supply any thickness you desire.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
