Dumb Question reguarding ECM Chip
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
I an old school hot rodder Never did much with car computers, my question is I have a 305 TBI with both Tbi Mods done, LT1 Cam bigger springs and 1.6 rockers and long tube headers. Once the engine is in and hooked up will the car run or should I say start with the factory chip. just to see if the engine rebuild was done and looking for major issues
thanks
chris
thanks
chris
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dumb Question reguarding ECM Chip
It will start with your stock L03 tune but to optimize your engine you will need to datalog and re burn your eprom. If you are using long tube headers and the o2 sensor is now down stream it will be harder for it to get up to 500 degrees to start working. You should install a heated o2.
Car: 1988 iroc
Engine: 350 30 over
cool thanks for you answer, Yea been looking at summit for the heated o2 sensor cause I have the single wire one
Engine: Lb9
Transmission: M20
Part number for the sensor.
25312179 (AFS-74)
Weather pack connector.
12126012 pt643
http://www.ebay.com/itm/ACDELCO-OE-S...#ht_1050wt_931
http://www.casperselectronics.com/st...oducts_id=1068
25312179 (AFS-74)
12126012 pt643
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
I used a 4 wire heated from a 95' Buick 3.8L. It was about $35
Engine: Lb9
Transmission: M20
Axle/Gears: 3:42
Axle/Gears: 3:42
IIRC, the AFS-74 part number worked in sync with certain aspects of the 7730 ecm better than our factory sensor
Engine: Lb9
Transmission: M20
you can use either with the 4 wire pins A and C will be grounds you can tie these two together on a pigtail harness. pin D will be the accessory powered 12v use a 10 amp fuse inline to protect this circuit. Pin B will hook to your factory purple oxygen sensor wire.
NinjaNife
Aug 23, 2015 11:49 AM
