Auto to manual swap question help plz !
Car: 91 z28
Engine: 5.7 350 TPI '91
Transmission: World class T-5
Axle/Gears: Stock ??
Hey my friends..
I have a 91 z28 350 Tpi. It was original auto, but converted to world class t-5. I cannot get idle to go below 1300 rpm. I have replaced
Idle air control valve
TPS sensor
Distributor
Spark plugs
Brand new injectors (stock 22lbs)
Alternator
Anything to do with idle ive changed as well as made sure my timin is 6* BTDC.
Any ideas and also since its now a converted stick should my timing change to accomadate the high idle? My understanding is manuals idle around 850 rpm. Thanks guys
TPS sensor
Distributor
Spark plugs
Alternator
Car: '87 Z-28
Engine: LT1-topped 400
Re: Auto to manual swap question help plz !
When you replaced the IAC, did you perform the minimum air setting procedure, where you punch out the cover on the throttle stop screw and adjust it with the IAC fully extended?
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
The ECM controls the idle, and it's higher for an automatic than a stick so a program change may be in order, also I do believe the timing is different for a manual than an automatic.
Car: '87 Z-28
Likely factors include incorrect minimum air setting, a vacuum leak, or a failed coolant temperature sensor.
I stand duly corrected on the timing.
Car: 91 z28
Thanks everyone for the help! Okay so no i didnt set the minimum air speed, where is this ALDL port at ? Ive looked around the steering wheel and by the fuse box to no avail. Again its a 91 z28! Thanks everyone for the input
Car: 91 z28
Ok so today i tried to set minimum air setting.. I connected ports A&B on the ALDL ( i think it was the ALDL not 100% sure
As ive never messed with it b4) i followed the steps and when i started the car with no IAC valve connected it steadily idle around 2000 RPM. I have the idle screw backed out all the way as well but still have high idle =[ i dont understand why it was idling at 2000rpm with no IAC valve, could this point to the real problem !?
Do you happen to know what the voltage is on your TPS? Should be around .59.
Car: 91 z28
Jus wanted to update everyone on what has happened. Car passed smogged, apprently i had no high idle the RPM guage wasnt accurate. Did some research and it does happen to these tach's a lot so HEADS Up!! Also i didnt need any chip at all for my conversion (auto to manual) my car is pulling hard thru all gears ! YEEYEE !!!!!
1992 Trans Am
Aug 8, 2015 08:16 PM
