Yay.. engine wont crank, how original...
Old Feb 18, 2012 | 11:17 AM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
Alright, here is the problem.. I have a 1990 iroc, 355 tpi and it just wont crank over. I'm at the gas station filling it up and then i try starting it, when the problem first began it was in the process of starting and then it just decided not too, the engine was actually cranking and then it just stopped.. I tried cranking it gain, I also heard the fuel pump starting before i did. THIS IS WHAT HAPPENS.. I hear it trying to crank, but it doesn't i just hear one stroke and then there is smoke, not a lot.. but enough to notice. It seems to be coming from somewhere on the right side of the car(starter?). so a good friend of mine came over, we tried jump starting it. That didn't wont, we tried his ta's battery.. that also didn't work. fast forward to 2am.. i get it towed back to my house. Now that I have let the battery charge over night i tried again, no dice. Now, this has happened before, the last time it happened it was because i had loose connections at the terminals, now i have them as tight as hell so i doubt that is even a issue. I probably wont be back to reply to this for a couple hour but input would be very appreciated .
Old Feb 18, 2012 | 01:19 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Yay.. engine wont crank, how original...
Check the starter out, pull it out and test it a few times. Hook it up to a spare battery or whatever. Sound like its not engaging im sure you know. So with it out you should be able to identify the problem. check the flywheel gears too
Old Feb 18, 2012 | 07:57 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
Yep, well I got the starter disconnected. I just have to get the exhaust out of the way so i can actually remove it. Mehh.. Its times like this when i realize I need to invest in a cheap economic daily driver, any thoughts? Haha.
Old Feb 18, 2012 | 08:03 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
time to upgrade to a smaller high torque mini starter.
Old Feb 18, 2012 | 08:05 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
That is exactly what chevy8588 told me earlier haha..
Old Feb 21, 2012 | 01:38 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
http://shop.advanceautoparts.com/web...___#fragment-2 So, this is the one i ended up ordering, anyone else ever use it?
Old Feb 21, 2012 | 01:45 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
You can't get the starter out just by tipping it? It took me awhile and a lot of adult language to finally find the right position but I was able to get it out without taking off the exhaust.
Old Feb 21, 2012 | 01:57 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
Yeah, unfortuanatly that wasn't going to happen for me, believe me i tried! It probably has someonething to do with the headers and y pipe and what not. It just wasn't going to budge.
Old Feb 21, 2012 | 02:38 PM
Richboll's Avatar
Engine: 305 TBI
Sorry, I missed the part about headers. I have a stock system. With headers, best to get the mini starter.
Old Feb 23, 2012 | 01:36 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
Okay, so starter came in sooner than usual . However, when i was taking the old one out a senosr popped out of its little fitting and i believe its probably broken. Its mounted on the passengers side cylinder head and its between cylinder 6 and 8. It looks like a metal prong, does anyone know what this could be before i take a picture and what not?
Old Feb 23, 2012 | 01:50 PM
Richboll's Avatar
Engine: 305 TBI
I think it is the temperature sensor for the cooling fan.
Old Feb 23, 2012 | 02:00 PM
X Jackal X's Avatar
Car: 1990 Iroc-Z
Engine: L98 355 TPI
Yeah, probably doesn't help without a pic, ill be back with one in a a little.
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
